bentaudun Posted September 20, 2020 Share Posted September 20, 2020 Hi all. Thank you for a great product! You have a really great API and a fantastic physics engine. The documentation is good and there are also some nice examples. I am very happy about the c# support. As a developer the top things I miss are: Exported documentation for the API (c#) so it can be visible in the IDE, see comparison of System Acos method vs Unigine MathLib Acos mehtod. It seems like it is not possible to use Unigine from a unit testing context, e.g. using NUnit Link to comment
silent Posted September 21, 2020 Share Posted September 21, 2020 bentaudun Documentation is available starting from 2.12 SDK Update (there should be *.xml file alongside the *.dll inside bin directory of your project): There might be some methods left undocumented (for example, MathLib.Acos is the lucky one). Try checking the World.GetNodeByNameWorld to see if it works. Regarding the NUnit support - we will check and report back to the corresponding topic. There is no any limitations on our side, so it must be some environment configuration issue. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
bentaudun Posted September 21, 2020 Author Share Posted September 21, 2020 Thank you :) The problem was that the xml file was not in the bin folder of the project. Perhaps documentation files are not included automatically. Anyway, I copied the xml documentation file to the bin folder and now the "quick help" in Rider works fine. I suppose the xml documentation could be more or less the same as can be found on developer.unigine.com for the API. Having the documentation available in the IDE is a huge plus :) Link to comment
silent Posted September 22, 2020 Share Posted September 22, 2020 Yeah, documentation copying is available for new projects (2.12+). If you upgraded it from previous version (2.11) you need to copy these files manually. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
