void Posted September 9, 2010 Share Posted September 9, 2010 class Node { string name; Node child[]; Node(string aName){name=aName;} }; void saveNode(Node node) { log.message("save node [%s] children count: [%i]\n",node.name,node.child.size()); foreach(Node n; node.child) saveNode(n); } int init() { Node root = new Node("zero"); Node one = new Node("one"); Node two = new Node("two"); root.child.append(1,one); one.child.append(2,two); root.child.append(3,new Node("three")); saveNode(root); return 1; } This code crashes application without any error message. Log: 13:01:15 Loading "worlds/vars.world" 186ms 13:01:15 save node [zero] children count: [2] 13:01:15 save node [one] children count: [1] 13:01:15 save node [two] children count: [0] The same behavior with vector. Link to comment
frustum Posted September 9, 2010 Share Posted September 9, 2010 Thank you. Recursion bug is fixed. As temporary solution you can use vector array with for/forloop cycle instead of foreach. save node [zero] children count: [2] save node [one] children count: [1] save node [two] children count: [0] save node [three] children count: [0] Link to comment
void Posted October 13, 2010 Author Share Posted October 13, 2010 I still get the same error in build of Unigine-20100907-src.. ( Link to comment
binstream Posted October 13, 2010 Share Posted October 13, 2010 I still get the same error in build of Unigine-20100907-src.. ( The bugfix will be incorporated into the next SDK update. Link to comment
