Naming Conventions
Is there a official naming convention for programming in Unigine2 ?
Following examples do not break the code but limit the functionality of the editor.
  • No spaces in project names
  • No underscore in ParameterCondition names
Hi Silent,
When encountering following problem I simply started a new project using “_”.
Pseudo code
public bool disable_someParameter = false;
[parametercondition(“disable_someParameter”, 1)]
public string s = shown in editor ;
public bool disableSomeParameter = true;
[parametercondition(“disableSomeParameter”, 1)]
public string s = hiden in editor”;
Issue with space in project name should be already fixed (it was found in 2.11).
Also there is no any restrictions on underscore usage in ParameterCondition. If you wan to show the exact name in the Editor you can use following code:
[Parameter(Title="disable_someParameter")]
[ParameterCondition("disable_someParameter", 1)]
public string s = "shown in editor" ;
The error does not seem to be consistent.
Yesterday the “_” set gave no hidden fields. now 2 out of 3 are hidden.
After reimporting the script all 3 where hidden.
image.png.30a8bce681ff17f4fd5efebdf0541b72.pngimage.png.25f8e3986c7f186cfa2e633cc24342c0.png
image.png.baf287b40b6af16b4e5797fe752f0c94.pngimage.png.f2d4e043dc7f08aa378fdfec7b1ab649.png
Hi David,
What is your SDK version where you are testing this behavior?
This issue with partial ParameterCondition displaying should be already fixed in the latest 2.12 SDK version (and it's not related to the underscore symbol, the update mechanism simply was bugged in 2.11).
Recreated the bug copied image v1 and _log1.txt log_1.txt
Then figured out the steps to recreated the condition.
Set the value to not default (highlighted in green) same value as default is aloud see image v2.
change the condition variable name and (auto)reimport.
The parameter will no longer be hidden.
Change the value back to default using the ccw arow (Normal grey).
RMB reimport and all is ok again.
For v2 _log.txt was not to be found so you get log.txt log.txt
Edited by david.cambre
