ExBemined Posted August 11, 2020 Share Posted August 11, 2020 (edited) In previous versions of Unigine (I believe it still worked in 2.9) it was possible to delete the script source code after making a build by adding an additional parameter to the world_load command. In Unigine 2.11 and 2.12 this does not seem to work anymore though, even though the documentation still mentions this trick: https://developer.unigine.com/en/docs/2.12/code/uniginescript/cache It still loads the world itself, but does not load and execute the script anymore, instead you get a "FileSystem::addVirtualFile(): can't find mount point" error. Is there a way to fix this? We do need to keep our script source out of the final builds as otherwise clients might be able to bypass some license checks that haven't been moved to C++ yet. Simple repro steps would be to create a fresh Unigine 2.12 script-only project in the SDK browser, add a "log.message("Hello world") to the init function and make a build. Then run the build, open the console and call the world_load command to generate the cache. Finally delete the .usc file from the build and start the build again and try to load the cache using the world_load command and instead of "Hello world" there is an error. Edited August 11, 2020 by Bemined Added repro Link to comment
silent Posted August 12, 2020 Share Posted August 12, 2020 Bemined Successfully reproduced this behavior. Right now I don't have any information if the script mechanism was removed. Need some time for debugging this. I will get back to you as soon as I get more information from the dev team. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
silent Posted August 13, 2020 Share Posted August 13, 2020 Could you please check if modifying source/engine/world/World.cpp will work in your case? Both changes are in the same function World::do_load_world(const char *p, const char *cache): // Patch 1 [int World::do_load_world(const char *p, const char *cache)] if (cache_name.size() && engine.filesystem->isFileExist(cache_name) == 0) // After: if (cache_name.size() && (engine.filesystem->isFileExist(cache_name) == 0)) // Patch 2 [int World::do_load_world(const char *p, const char *cache)] if (script_path.isValid()) // After: if (script_path.isValid() || cache_name.size()) Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
ExBemined Posted August 17, 2020 Author Share Posted August 17, 2020 Patch 2 seems to do the trick, thanks! Link to comment
