[SOLVED] how can i separate a network function so i can run it each frame?.
ull disclosure: i am not a very experienced C++ developer so i think i am asking something basic.
i have this snippet of code that start my client:
    printf("\nconnecting client (insecure)\n");
    double time = 100.0;
    const double deltaTime = 0.01f;
    ClientServerConfig config;
    uint64_t clientId = 0;
    random_bytes((uint8_t*)&clientId, 8);
    printf("client id is %.16" PRIx64 "\n", clientId);
    Client client(GetDefaultAllocator(), Address("0.0.0.0"), config, adapter, time);
    Address serverAddress("127.0.0.1", ServerPort);
    if (argc == 2)
        Address commandLineAddress(argv);
        if (commandLineAddress.IsValid())
            if (commandLineAddress.GetPort() == 0)
                commandLineAddress.SetPort(ServerPort);
            serverAddress = commandLineAddress;
    uint8_t privateKey[KeyBytes];
    memset(privateKey, 0, KeyBytes);
    client.InsecureConnect(privateKey, clientId, serverAddress);
    char addressString[256];
    client.GetAddress().ToString(addressString, sizeof(addressString));
    printf("client address is %s\n", addressString);
    signal(SIGINT, interrupt_handler);
    while (!quit)
        client.SendPackets();
        client.ReceivePackets();
        if (client.IsDisconnected())
            break;
        time += deltaTime;
        client.AdvanceTime(time);
        if (client.ConnectionFailed())
            break;
        yojimbo_sleep(deltaTime);
    client.Disconnect();
    return 0;
but i need this part to be a separate function:
    while (!quit)
        break;
    time += deltaTime;
        break;
because this is the actual function that keeps the client connected to the server.
my question is, how can i separate the main function that creates the actual client, and save it as a global value?
as you can see snippet 2 needs client but i cannot just copy or create client because i get the following errors:
enter image description here enter image description here
and here is how the class is made: enter image description here
the thing is i need the separate the function so i can run it each frame but i don't know how i can save client as a global value.
thanks in advance.
If I understand the question correctly, then you can try to place the client's logic in the AppSystemLogic. To do this, you can add to the header file:
class AppSystemLogic : public Unigine::SystemLogic
    AppSystemLogic(int argc, wchar_t *argv[]);
    void update_client();
    Client *client{nullptr};
    bool is_valid_connection{false};
    float time{0.0f};
and add to AppSystemLogic.cpp:
AppSystemLogic::AppSystemLogic(int argc, wchar_t *argv[])
    client = new Client(GetDefaultAllocator(), Address("0.0.0.0"), config, adapter, time);
    if (argc == 2)
    client->InsecureConnect(privateKey, clientId, serverAddress);
    is_valid_connection = true;
AppSystemLogic::~AppSystemLogic()
    if (client)
        client->Disconnect();
        delete client;
int AppSystemLogic::update()
    update_client();
void AppSystemLogic::update_client()
    if (!is_valid_connection || !client)
        return;
    client->SendPackets();
    client->ReceivePackets();
    if (client->IsDisconnected())
        is_valid_connection = false;
        return;
    time += App::getIFps();
    client->AdvanceTime(time);
    if (client->ConnectionFailed())
        return;
When creating the system logic, use the new constructor:
AppSystemLogic system_logic(argc, argv);
AppWorldLogic world_logic;
AppEditorLogic editor_logic;
Unigine::EnginePtr engine(UNIGINE_VERSION, argc, argv);
If additional functions are needed to work with the client, then they can simply be added to the system logic.
@karpych11 Thank you so much!
i did tried doing what you said and i gave me a better idea to work with c++  and because of that i was able to make it work!
here is a screenshot of the code:
with what you showed me i am now able to make private values and can just use them in my functions, i am so happy you thought me this! :D
now i am actually capable of connecting to a server while the game is running!, now my next step is to have them communicate positions :D i am so exited! thank you!!!
  • silent changed the title to [SOLVED] how can i separate a network function so i can run it each frame?.
