Sign in to follow this
Polygon offset parameter is not working in 2.12
It seems, that in 2.12 polygon offset parameter in material stopped working. We ve been use it in some cases to prevent z-fighting, for example (rev 1597+):
\data\asset_library\nodes_for_locations\MedeaPedestalA_dekor_medea.node
Share this post
Link to post
Polygon offset has been removed. Closest alternative is geometry inflation (baloon / wire modes) option. Could you please check if that will work in your case?
This parameter has a lot of dependencies from the exact GPU model and driver. We need some additional time for research how to make it more stable.
Share this post
Link to post
We have decided to modify these meshes. It will be cleaner solution and there is only cca 50 of them.
Share this post
Link to post
