[SOLVED] Unparent Node
Hello I have a node within a node hierarchy and I am trying to unparent it by setting Node.SetWorldParent(null)
My goal is to have the separated node stay in position and not following the parent node.
If I debug such node Parent is null but node keeps on moving as if attached to parent
Am i missing something ?
thanks
Fred
Share this post
Link to post
There is another function Node.setParent(), did you try it with this?
Greetings
Edited by ipg_jallmenroeder
Share this post
Link to post
yes I tried both...thanks
Share this post
Link to post
Hello Fred,
Is it C# or C++? Because of capitalizing I thought it's a C#. Anyway, this method works as expected with both.
I tried the simplest way:
C# component:
	private void Init()
		// write here code to be called on component initialization
		Node node = World.GetNodeByName("Sphere"); //It's a parent
		Node node2 = World.GetNodeByName("Cuboid");
		node2.SetWorldParent(null); //Commenting this line causes both nodes to move as expected
	private void Update()
		node.WorldTranslate(0.0f, 0.1f, 0.0f); // Here I move the parent along Y axis
Almost same code in C++:
Unigine::NodePtr node1;
Unigine::NodePtr node2;
AppWorldLogic::AppWorldLogic() {}
AppWorldLogic::~AppWorldLogic() {}
int AppWorldLogic::init()
	node1 = World::getNodeByName("material_ball"); //Parent node
	node2 = World::getNodeByName("Cuboid");
	node2->setWorldParent(nullptr);
int AppWorldLogic::update()
	node1->worldTranslate(0.0f, 0.1f, 0.0f);
Could you please share a sample with your code?
Thanks.
Share this post
Link to post
Solved, sorry it was my mistake I had to unparent the player not the node itself...
thanks for the quick response!
Fred
Edited by fred.naar
Share this post
Link to post
