console - size
Is there a value for the size of the console?
I want it to be smaller and not fill 3/4 of the screen.
thx.w
Link to post
Okay.
Can I hack that somehow.
I have the case, that I need to test various paramters while running the project. (DOF, TAA).
I only can compare it visually and it is not very good to see if the text is all over the image if I change parameters.
So if the console is as minimal (just the imput line), it would help a lot.
thx.w.
Link to post
For that use-case I guess you can ask programmers to write a small editline widget (more likely without auto-completion, but it also can be done) that will apply console commands for you :)
That's pretty much common use-case for console usage, we will consider to implement some lightweight mode in the future, thanks for the idea!
Link to post
  • 3 months later...
