Widgets not useable when using ALIGN_BOTTOM or ALIGN_RIGHT
it seems there is an problem with child widget-usage when the parent one is attached to the main gui via addChild with either ALIGN_BOTTOM or ALIGN_RIGHT. I reproduced the bug also in 2.10.0.2.
Short steps to reproduce:
  1. Open the existing C++ project "WidgetCallbacks" in the Widget folder of the C++ example projects.
  2. Modifying line 51 by changing addChild() parameters with eiter ALIGN_RIGHT or ALIGN_BOTTOM.
  3. Run -> no button interaction and window won't be repositioned.
This bug also happens when those two alignment-parameters are called in combination with other ones. So ALIGN_LEFT | ALIGN_TOP will work, but ALIGN_LEFT | ALIGN_BOTTOM won't.
Best
Christian
Link to post
  • 2 weeks later...
In this case, with flags you need to use ALIGN_OVERLAP. This flag makes the window movable. Also it affects the alignment of elements.
Link to post
Hello karpych11,
yes I was aware of that ALIGN_OVERLAP statement. But I didn't know it was intended because seems a little bit confusing when using ALIGNE_LEFT | ALIGN_TOP will work without any problems while using ALIGN_RIGHT or ALIGN_BOTTOM in any combination don't.
Link to post
Yeah, there always a room for improvements (in internal GUI framework). We will think how can we improve this behavior in the future SDK updates.
Link to post
