[SOLVED] No option to create C# project with .Net Framework
Hey guys,
Few days ago I created C# test project, where I found problem with access to System.IO.Ports. After some time I found, that it is because of .net core, which has no System.IO.Ports components. When I wanted to create new project with .Net Framework, there was no option to choose it.
Thanks
Roman
Share this post
Link to post
Have you tried to add this nuget package? https://www.nuget.org/packages/System.IO.Ports
It should be compatible with .NET Core SDK.
We doesn't offer .NET Framework option for new projects since the .NET future releases will be merged to a new .NET 5 standard (based on a .NET Core). In theory there should be a more or less straightforward migration for that.
Share this post
Link to post
OK. I thought, that .Net Framework is supported based on this website (https://developer.unigine.com/docs/2.11/code/csharp/application). I will give it a try to add this nuget package, but I cannot find way how to do this.
Thanks
Share this post
Link to post
In the root directory of your project you can find a .csproj file. You can add System.IO.Ports to it via following command line:
dotnet add "C:\My_Unigine_Project\My_Unigine_Project.csproj" package System.IO.Ports --version 4.7.0
If everything ends fine you will see the additional lines in your project file:
<ItemGroup>
   <PackageReference Include="System.IO.Ports" Version="4.7.0" />
</ItemGroup>
Share this post
Link to post
Thanks !!! It did a trick.
Share this post
Link to post
