werner.poetzelberger Posted June 17, 2020 Posted June 17, 2020 Seems that the Minimum Scale isnt be respected. Can this be? V 2.11
silent Posted June 18, 2020 Posted June 18, 2020 WorldClutter is deprecated object, so some parameters may not work. We do recommend to switch to MeshClutter / Cluster objects instead. These will additionally gives you a performance boost due to multithreaded MeshClutter / Cluster updates. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
werner.poetzelberger Posted June 18, 2020 Author Posted June 18, 2020 eek. But I can leave the WorldClutter in the project if I need to? I will switch to the MeshClutter. Thank you!!
silent Posted June 18, 2020 Posted June 18, 2020 WorldClutter probably will stay for couple of releases, but eventually will be removed completely. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
werner.poetzelberger Posted June 18, 2020 Author Posted June 18, 2020 Mesh Clutter Min Scale is not woking as well.
silent Posted June 18, 2020 Posted June 18, 2020 Scale parameter works only if you have loaded Image Mask for the Clutter. Can you try with mask assigned? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
werner.poetzelberger Posted June 18, 2020 Author Posted June 18, 2020 (edited) I have one on. Not affecting the result. Any other parameters? Basically I created a new object, so all of the parameters should be default. Edited June 18, 2020 by werner.poetzelberger
silent Posted June 18, 2020 Posted June 18, 2020 It looks like I can't reproduce this behavior. Could you please send us a minimal test scene? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
werner.poetzelberger Posted June 18, 2020 Author Posted June 18, 2020 You know what.... I loaded a different mesh, not it works..... I did something wrong I guess. Sry for using your precious time ;) best.w.
