Sign in to follow this
Plugin Interface is deprecated, replacement?
The plugin Interface is marked as deprecated. We use it to have a Unigine GUI either embedded in the viewport (not using the plugin) or extern to the viewport  (using the plugin). This allows us to have the same GUI, embedded for users with a single screen or extern for users wit h multiple screens, so they can arrange windows as they suit.
As the plugin is deprecated, what should we use instead? (note that the c++ code samples still use it)
Share this post
Link to post
Hi Stephane,
It's a bit complicated with this plugin. Yes, it is marked as deprecated, but it still works, and we're using it for our internal projects. At the moment there no reason to be concerned about this.
When the time comes we'll offer another solution.
Thanks.
Share this post
Link to post
