dongju.jeong Posted June 7, 2020 Share Posted June 7, 2020 (edited) Entity packet's clamp option work only on terrain. Can it be clamped on airports or flat objects? Edited June 7, 2020 by dongju.jeong Link to comment
cash-metall Posted June 8, 2020 Share Posted June 8, 2020 Hi! https://developer.unigine.com/en/docs/2.11/api/library/plugins/ig/api/managerinterface?rlang=cpp&words=ig%2Cmanager%2Cmanag#setTerrainIntersectionMask_int_void you need to specify intersection mask for "ground" surfaces 1 Link to comment
dongju.jeong Posted June 10, 2020 Author Share Posted June 10, 2020 I was already using IG's setTerrainIntersectionMask(int) function and specifying the surface intersection mask of the ground. so HAT/HOT response or LOS is work. but Entity's clamp doesn't work...Entity is clamped only on the terrain. Link to comment
