Gryphon_de Posted July 22, 2011 Share Posted July 22, 2011 Hi! I don't understand how export-import scaling works. See the case: 1) Create 1x1x1 meters box in 3ds Max 2011; 2) Export it to Unigine mesh. Result (1st attachment): Sacale field is between 0.003m and 0.254m. What is that? Why so? 3) Adding this MESH to Unigine; 4) Create box mesh from Unigine library; 5) Placing these 2 boxes near each other. Result (2nd attachment): Imported box (left one on picture) is larger then box from library. What is that? Why so? Link to comment
steve3d Posted July 24, 2011 Share Posted July 24, 2011 It's not a problem, actually, it's your 3dsmax's unit setting problem, try using generic unit in file unit and system unit Link to comment
manguste Posted July 25, 2011 Share Posted July 25, 2011 It's not a problem, actually, it's your 3dsmax's unit setting problem, try using generic unit in file unit and system unit Steve is right, you need to use generic units instead of metric units. As for the exporter, the scale can be set in the range [0,1;10]. Link to comment
