Unigine SDK 2011-07-21
Great work!Thanks! And how you use it, for examle, engineConsole::setInt()? Unigint script provide engine.console.setInt() syntax only, does not?
#define NOBUILTIN
#include <codepath/uniginescript.h>
at the beginning of your Unigine app (this will cause the preprocessor to remove this code when the application is running) or
run unigine with the command line switch
--extern_define NOBUILTIN
#define NOBUILTIN
Thanks
Actually, our problem is mostly that the executables in the SDK are _x86 which appear to be used only with the simulator. The release executables are the ones we need.
Sorry, this is a wrong postfix, but executables in the iOS SDK are native for iOS
~/UnigineSDK-source-2011-07-21-ios$ file bin/*
bin/main_x86d.ios: Mach-O executable acorn
bin/main_x86.ios:  Mach-O executable acorn
This a bug in build.py, fixed.
