2.11.0.2 Hotfix Released!
Thanks to your valuable feedback provided via all our channels we’ve resolved a number of issues that were not fixed in 2.11.0.1. These are primarily bug fixes, the active feature development for upcoming 2.12 release is going on in other branches.
  • Reduced Editor freezes on editing a Landscape Terrain object with a smoothing brush. Please note that the control key for the smoothing brush has changed, so instead of pressing and holding the Shift key you can now simply hit "V".
  • Fixed an issue with a broken hyperlink used to create a new child material for ULON-based materials (e.g., particles_base, landscape_terrain_detail_base).
Engine
  • Fixed issues with detecting collisions with the Landscape Terrain for systems with a CPU having 2 and less cores. Single-threaded mode for physics and pathfinding is no longer available, so the following console commands were removed:  physics_threaded, pathfind_threaded, and engine_threaded.
  • Fixed an issue with receiving click events from a widget having a callback assigned when there are multiple visible Gui objects present in the scene.
  • The render_border console command now preserves modifications made to the projection matrix.
  • Fixed issues with FFP rendering in SOLID mode on OpenGL.
  • Fixed an issue with loading of nested Node References in C# API.
  • Fixed a crash related to NuGet packages in C#.
  • Added a new IsDeleted property for nodes added to the delete queue. The C# Component System shall no longer retrieve components for such nodes.
  • Added null-value checks and the swap() method to the C++ Component System.
SDK Browser
  • Fixed an issue with license activation for a cross-platform product.
Updated version of documentation is available as 2.11.
  • Like 5
Link to post
