helmut.bressler Posted May 20, 2020 Posted May 20, 2020 Hello, I fear the removal of the index based property parameter access in 2.11 is causing some issues for the tracker. At least animating float parameters doesn't work anymore. Reproducing that issue is easy, inherit from the following property and animate the myFloat parameter in the Tracker. <?xml version="1.0" encoding="utf-8"?> <property version="2.7.3.0" name="custom_prop" manual="1"> <parameter name="myFloat" type="float">0.5</parameter> </property> its not changing and spills out a lot of error messages in the console. Thank you for looking at this Helmut
morbid Posted May 20, 2020 Posted May 20, 2020 Hello Helmut, I reproduced this issue. Is it blocking your work at the moment? Sorry for the inconvenience. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
werner.poetzelberger Posted May 20, 2020 Posted May 20, 2020 (edited) Hey Morbid, we have finished a big project, ported that to the 2.11 because of 2 reasons, DOF banding issue, Border plugin for screenspace refl. Tracker is a very essential part of our projects and we need it to finish it. So, yes, this is blocking us from finishing the project in 2.11. As long as this is not working, we cant contiue, but we can stay with 2.10 and wait for an update or switch to 2.12. Let me know, what you plan, so we can react. Thanks! Best. Edited May 20, 2020 by werner.poetzelberger
morbid Posted May 21, 2020 Posted May 21, 2020 Hi Werner, hi Helmut. Please check the attached fix. Just unpack to data folder the archive, then run the editor. Let me know if this solved your problem. core.7z How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
helmut.bressler Posted May 22, 2020 Author Posted May 22, 2020 Hello Morbid, thank you for the quick update, works totally fine here! Many thanks Helmut
helmut.bressler Posted May 22, 2020 Author Posted May 22, 2020 Hello Morbid, technically the fix is working, but unfortunately it has a memory leak :-( It might be less disturbing when you use the tracker only in the editor, but we have integrated the tracker in our applications, as described for instance in:https://developer.unigine.com/en/docs/2.6/code/uniginescript/scripts/systems/unigine_tracker/run?rlang=cpp We mainly use it for animating stuff depending on the camera position (we typically have fixed camera paths) and for animating daytime dependent things. I believe the memory leak already shows up when you are animating only a single property parameter, but only very slowly. Therefore I have attached a property which has 20 parameters and a corresponding track file. With 180fps I get around 1 MB/second. Thank you for looking at it Helmuttest_leak.track custom_prop_0.prop custom_prop_0.prop.meta custom_prop_parent.prop custom_prop_parent.prop.meta
morbid Posted May 26, 2020 Posted May 26, 2020 Hello Helmut, Please check the new version, file is attached. Put it in data/core/systems/tracker/parameters/ property.parameters How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
helmut.bressler Posted May 26, 2020 Author Posted May 26, 2020 Hello Morbid, many thanks, the memory leak is gone! Cheers Helmut
