Options -> Always run work conditions
Wy checking Options -> Always run checkbox takes effect only in passage demo? In character demo this point didn't work. In our game with PlayerActor instance this point don't work also. What a conditions to use this ability? Thanks.
"Always run" is a little bit missleading as it means "control state returns RUN state if shift key is NOT pressed and WALK if pressed". Also see this post
Don't understand... ones again, how it works now in my machine:
passage demo:
always run unchecked - player run only if we are pressed Shift, and walk if Shift is not pressed
always run checked - player walk only if we are pressed Shift, and run if Shift is not pressed
character demo:
always run checked - player run only if we are pressed Shift, and walk if Shift is not pressed
so in character demo "Always run" isn't work at all. Could you say please, in your demos passage and character both work identity? Because my character demo don't work right, and our project don't work right, and we try to understand, what different between passage and character demos to fix our game to.
The difference is that character demo uses character controls from high-level character script system. And passage demo does not.
Character demo controls does not use global controls settings (including always run mode and input settings from system menu).
I see, thanks
