werner.poetzelberger Posted May 7, 2020 Posted May 7, 2020 ... by tracker. The variable is not listed when trying to add a track. Can you add thoses parameters in upcoming version? I had this before with some values.... There are some entries somewhere in the core inst it? Can you point me please again to those files... Cheers Werner
silent Posted May 8, 2020 Posted May 8, 2020 Hi Werner, Just add shadowDistance parameter to the <Project>/data/core/systems/tracker/parameters/node.parameters: <parameter type="node.light.shadowDistance" track="float" min="0" max="inf" object="Light"> <set>OBJECT.setShadowDistance(VALUE);</set> <get>VALUE = OBJECT.getShadowDistance();</get> </parameter> Not sure about min value, maybe -inf is the right value for that :) 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
