[SOLVED] Public variables not exposed in Editor
Hello everyone!
I am having difficulties regarding exposing things in the editor. When I make a public variable it is supposed to show up in the editor, but it never does. And it doesn't work no matter the type of variable.
Here's the code:
using System;
using System.Collections;
using System.Diagnostics;
using Unigine;
[Component(PropertyGuid = "9d726b584d9b76d7b9aca64ab1aee121ec3c880c")]
public class TowerSpawnUI : Component
	public Mesh CubeMesh;
	private void Init()
		Gui GUI = Gui.Get();
		WidgetButton Btn = new WidgetButton(GUI, "Click Me!");
		Btn.AddCallback(Gui.CALLBACK_INDEX.CLICKED, new Widget.Callback0Delegate(BtnClicked));
		GUI.AddChild(Btn);
	void BtnClicked()
		new Mesh(CubeMesh);
Here's what shows up in the editor:
Not all types of variables can be displayed in the editor. You can find all available options in C# Component Samples in the script csharp_component_samples/Components/components/ComponentParameters.cs. In your case with a mesh, you can use the asset link:
[ParameterAsset (Filter = ".mesh")]
public AssetLink CubeMeshLink;
and then create a mesh:
Mesh mesh = new Mesh (CubeMeshLink.Path);
Thank
7 minutes ago, karpych11 said:
Thank you for replying!
But, sadly, this isn't working for some reason. Even with simple things such as Integers and Floats (Which I know already have an inspector thing built in).
Here's, again, what the code looks like and the Editor
using System;
using Unigine;
	[ParameterAsset(Filter = ".mesh")]
	public AssetLink CubeMesh;
	public int Test;
	private void Init()
		WidgetButton Btn = new WidgetButton(GUI, "PooPoo");
		GUI.AddChild(Btn);
	void BtnClicked()
		Mesh mesh = new Mesh(CubeMesh.Path);
Could you please show us your data folder contents in Asset Browser? If everything is OK you will see only the single .cs file:
If you have some additional .prop files it would mean that something bad is happens. Engine log file can be also useful to see (you can get it from <Project_Dir>/bin/log.html).
That's how your component is looking in my case - new component was created via Editor (and I didn't replaced the auto-generated GUID when copied your code):
Sure, here's what it looks like in my editor (Though, from looking at your screenshot, the only thing I think could make a difference is the CS Template)
I also had a look through my log, And when looking through the log, there was 3 missing GUIDs, however, the code was still running fine and all the GUI stuff loaded at Runtime.
Here's the log file just in case you want to have a read:log.html
Edited by SeaPeaMe
I can see the issue (it's really stupid, btw). Could you please open generated .csproj file in the root directory of your project and replace all the:
<AssemblyName>Physics Sandbox</AssemblyName>
with
<AssemblyName>Physics_Sandbox</AssemblyName>
Here how it looks like on my PC:
After that simply reimport .cs component and everything should work fine. We will fix this bug in the upcoming SDK update.
I have replaced those things in the "Physics Sandbox.csproj" file, and it still isn't working!
If you want I can email you the project so you can have a deeper look into it.
  • silent changed the title to [SOLVED] Public variables not exposed in Editor
