andrew.kumlin Posted April 26, 2020 Posted April 26, 2020 After following the documentation here for setting up sockets in c#. After being unsuccessful in my own project I opted to create a blank one and just copy and paste the code in the correct location. However I still cannot run the game at that point. I receive about thirty errors for each time I try to access the Socket or Blob class. The documentation didn't mention adding any references so I'm wondering if there is something wrong with my .Net setup? When I look at the code in visual studio I receive an error telling me to either target a version that supports .Net core 2.1 or lower. Or use a version of the SDK that supports 2.2. 'Socket' does not contain a definition for 'open' and no accessible extension method 'open' accepting a first argument of type 'Socket' could be found (are you missing a using directive or an assembly reference?)
andrew.kumlin Posted April 26, 2020 Author Posted April 26, 2020 Also here are the dotnet sdks I have installed
mark.pizzolatto Posted April 26, 2020 Posted April 26, 2020 Greetings Andrew - could you post the code itself so we can see what you have? Just the basic code would work, other wise it will be harder to diagnose it.
andrew.kumlin Posted April 27, 2020 Author Posted April 27, 2020 Here is the full AppWorldLogic.cs using System; using System.Collections.Generic; using System.Linq; using System.Text; using System.Runtime.InteropServices; using Unigine; namespace UnigineApp { static class Constants { // UDP port to be used public const int UDP_PORT = 8889; // UDP receive buffer size public const int RECV_SIZE = 7; // UDP send buffer size public const int SEND_SIZE = 7; } /// Class representing the Server Socket class ServerSocket { Socket socket; /// Server constructor public ServerSocket() { // creating a UDP socket socket = new Socket(Socket.SOCKET_DGRAM); // opening a socket on the specified port with a specified broadcast address socket.open("127.255.255.255", Constants.UDP_PORT); // setting the size of the sending buffer socket.send(Constants.SEND_SIZE); // setting the socket as a broadcasting one socket.broadcast(); // setting the socket as a non-blocking one socket.nonblock(); } /// Server destructor ~ServerSocket() { // closing the socket socket.close(); } /// method sending a message to a certain client public void send_message(short client_num, string message) { // preparing a message to be received by a client with a given client_id Blob blob = new Blob(); blob.clear(); blob.writeShort(client_num); blob.write(Marshal.StringToHGlobalUni(message), (uint)message.Length); // getting message size uint size = blob.getSize(); // setting current position to start blob.seekSet(0); // sending the message socket.writeStream(blob.getStream(), size); blob.clear(); } }; /// Class representing the Client Socket class ClientSocket { Socket socket; int id = 0; /// Client constructor public ClientSocket() { // creating a UDP socket socket = new Socket(Socket.SOCKET_DGRAM); // opening a socket on the specified port socket.open(Constants.UDP_PORT); // setting the size of the receiving buffer socket.recv(Constants.RECV_SIZE); // binding the socket to an address figured out from the host used for socket initialization socket.bind(); // setting the socket as a non-blocking one socket.nonblock(); } /// Client destructor ~ClientSocket() { // closing the socket socket.close(); } public void setID(int num) { // setting client's ID id = num; } /// method checking for received packes from the server public int update() { // preparing a blob to read the message into Blob temp_blob = new Blob(); temp_blob.clear(); // reading data from the socket socket.readStream(temp_blob.getStream(), Constants.RECV_SIZE); if (temp_blob.getSize() > 0) { // setting current position to start temp_blob.seekSet(0); // getting client's ID short num_client = temp_blob.readShort(); // checking if the received message is addressed to this particular client and processing it if (num_client == id) Log.Message("\nClient[{0}] - OPERATION_CODE: {1}", id, temp_blob.readLine()); } return 1; } }; class AppWorldLogic : WorldLogic { //declaring server and client sockets ServerSocket server_socket; ClientSocket[] clients = new ClientSocket[5]; // World logic, it takes effect only when the world is loaded. // These methods are called right after corresponding world script's (UnigineScript) methods. public AppWorldLogic() { } public override bool Init() { server_socket = new ServerSocket(); // Write here code to be called on world initialization: initialize resources for your world scene during the world start. for (int i = 0; i < 5; i++) { clients[i] = new ClientSocket(); clients[i].setID(i + 1); } return 1; } // start of the main loop public override bool Update() { // Write here code to be called before updating each render frame: specify all graphics-related functions you want to be called every frame while your application executes. Controls controls = Game.Player.getControls(); // sending messages on keys pressed to clients 2 and 5 if (controls.clearState(Controls.STATE_USE) == 1) server_socket.send_message(2, "S"); else if (controls.clearState(Controls.STATE_FORWARD) == 1) server_socket.send_message(5, "F"); else if (controls.clearState(Controls.STATE_BACKWARD) == 1) server_socket.send_message(5, "B"); else if (controls.clearState(Controls.STATE_MOVE_LEFT) == 1) server_socket.send_message(5, "L"); else if (controls.clearState(Controls.STATE_MOVE_RIGHT) == 1) server_socket.send_message(5, "R"); // updating clients for (int i = 0; i < 5; i++) clients[i].update(); return 1; } /* ... */ } }
silent Posted April 27, 2020 Posted April 27, 2020 It looks like Sockets documentation is slightly outdated, we will update it soon. Please, check the attached .cs file with corrected logic. AppWorldLogic.cs How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
silent Posted April 27, 2020 Posted April 27, 2020 Also, Visual Studio requires very specific .NET Core SDK version to be installed (2.2.207 or 2.2.110): https://developer.unigine.com/en/docs/2.11/troubleshooting/dotnet_issues?rlang=cpp#install_dotnetcore_sdk_windows How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
andrew.kumlin Posted April 27, 2020 Author Posted April 27, 2020 Thank you for your helpful and timely response!
