Move scene left
I need to do a display like this,The world scene is on the left and the UI is on the right.。
  • 4 years later...
I have the same question.
  • 1 month later...
You need to use EngineWindowGroup: https://developer.unigine.com/docs/future/api/library/gui/class.enginewindowgroup
but the first window needs to be equated to the main window in the application so that the render is displayed there:
EngineWindowViewport main = WindowManager.MainWindow;
Add second:
EngineWindowViewport second = new("Second", 100, 100);
The sizes are not important, because adding them to a group resets them. In example, two windows are created, after which the width of the second one (at index 1) is changed to 1/5 of the total.
EngineWindowGroup group = new(EngineWindowGroup.GROUP_TYPE.HORIZONTAL, "Group", 1920, 1080);
group.Add(main);
group.Add(second);
main.UpdateGuiHierarchy();
main.SetHorizontalTabWidth(1, 1920 / 5);
main.Show();
group.Add(main);
group.Add(second);
group.SetHorizontalTabWidth(1, 1920 / 5);
group.Show();
I've already tried it. The window decorations are turned on and I can't disable it.
Yes, you cannot change the styles of child elements in window groups. If you need to "split" without separate windows, then there is an option to use WidgetVBox:
Code:
Gui gui = WindowManager.MainWindow.Gui;
WidgetVBox widgetVBox = new(gui);
widgetVBox.Height = gui.Height;
widgetVBox.Width = 200;
widgetVBox.SetSpace(0, 5);
widgetVBox.Background = 1;
widgetVBox.BackgroundColor = new vec4(0, 0, 1, 1);
WidgetButton but = new WidgetButton(gui, "button");
but.SetPosition(2, 2);
widgetVBox.AddChild(but);
WindowManager.MainWindow.AddChild(widgetVBox, Gui.ALIGN_EXPAND | Gui.ALIGN_OVERLAP | Gui.ALIGN_TOP | Gui.ALIGN_RIGHT);
Edited by moriVotum
Such panel rendered on top of 3D-vewport. The question was about separate 3D-view.
Hello, there is a sample doing something really similar to what you need:
SDK Browser > Samples > Demos > C++ Samples > multi_view_split > SplitScreenCamera.h/cpp
The trick is to capture the 3D rendering into a WidgetSpriteViewport for your 3D view and render this widget over the left side of your game window.
