[SOLVED] Writing messages to the console (Editor & in-game)
I'm trying to figure out how to write messages to both or either of the in game and IDE consoles, in C# components.
I've done this,
Unigine.Console.Run("show_messages 1");
Unigine.Log.Message("Begun title sequence./n");
And show_messages shows up in both consoles, however the following Log.Message, does not?
Not sure for the C# side, but the C++ side a command prompt opens when the game runs;
Unigine.Log displays in that command prompt for me.
This code should print messages:
  • In game console
  • In the IDE console (I used VS Code)
  • On the screen
It will print nothing in the Editor console since Editor can't run C# logic.
Here's the component:
using System;
using System.Collections;
using Unigine;
[Component(PropertyGuid = "69615053347c1996d89403fd993ef5380ccdb737")]
public class log : Component
	private void Init()
		// write here code to be called on component initialization
	private void Update()
		// write here code to be called before updating each render frame
		Unigine.Log.Message("Begun title sequence.\n");
Ah thank you I get what I did wrong I think. I was trying to send the message within the Init() function. I guess before the console was ready. Cheers.
  • silent changed the title to [SOLVED] Writing messages to the console (Editor & in-game)
