Problem while running a project
I get File Not Found error when i run a project.
"File "/home/ali/Documents/UNIGINE Projects/Explore/bin/Explore_x64.dll" does not exist"
anything ii should take care for future problems silent?
still facing the same problem, same file not found error even though .net sdk version 3.1.201 is installed
My system is  LM "Tricia" 19.3 it says, supported linux mint versions are 17 and 18
There is no full list of supported OS for Linux. Since Mint is pretty much similar to other Debian and Ubuntu-based distros you can still try to install it that way described in documentation. Before installing 2.2.x you need (just in case) to delete currently installed 3.1 .NET Core SDKs.
We are currently migrating to .NET Core 3.1 and plan to introduce support for it in 2.12 SDK update. Until that only 2.2.x will be supported.
