[SOLVED] Two identical library have become problematic
using System;
using System.Collections;
using System.Collections.Generic;
using Unigine;
Unigine.Console
System.Console
01-How to use Console.Run for Unigine?
Unigine.Console.Run("LoadWorld MyWorld01");
02-How to see Log.Message in Unigine?
Log.Message("RUNING....!!");
Quote
By default all messages are displayed only in console. To see the log messages without opened console you need to execute following code:
Console.Run("show_messages 1");
Please, keep in mind that C# logic is only works when you launch the process via green play button.
Regarding the first issue, there is no such console command as "LoadWorld". You need to use Unigine.Console.Run("world_load my_world"); You also may need to remove Using Unigine; to understand which methods from which classes are called.
YOU SOLVED & I SAW THAT , THANK YOU MR @silent
using System;
using Unigine;
void Update()
	Unigine.Console.Run("Ahmad Karami...");
  • silent changed the title to [SOLVED] Two identical library have become problematic
