Transformation matrix
I am trying to add a force to a BodyRigid in local coordinates using body.AddForce, but as I see it adds the forces in world coordinates not in local coordinates.
In Unity or Unreal you can convert from local to world coordinates transform.transformdirection
I tried using
MathLib.Inverse4(body.Transform)
but I am not getting the expected results....
I am sure it is there somewhere but I can't find it...
thanks
Fred
Edited by fred.naar
Thank you, I read this, it was quite useful.
After some trial and error here's the way to transform a vector from local to world:
        vec3 wf = f*(MathLib.Inverse(node.GetWorldRotation()));
  • 4 weeks later...
This work as well
// Track the player rotation in world
		vec3 directionx = node.GetWorldDirection(MathLib.AXIS.X); // right vector rotated to world
		vec3 directiony = node.GetWorldDirection(MathLib.AXIS.Y); // witch direction player is facing
if (Input.IsKeyPressed(forward_key))
				node.ObjectBodyRigid.AddForce(vec3.ZERO, directiony * force_multiplier * ifps);
			if (Input.IsKeyPressed(backward_key))
				node.ObjectBodyRigid.AddForce(vec3.ZERO, -directiony * force_multiplier * ifps);
			if (Input.IsKeyPressed(right_key))
				node.ObjectBodyRigid.AddForce(vec3.ZERO, directionx * force_multiplier * ifps);
			if (Input.IsKeyPressed(left_key))
				node.ObjectBodyRigid.AddForce(vec3.ZERO, -directionx * force_multiplier * ifps);
Edited by samuel.bruner
