burakdogancay Posted March 12, 2020 Share Posted March 12, 2020 (edited) I wanted to write to you at the camera point. I mentioned that the problem about the camera accuracy has been solved in the subject I opened past days. At this stage, I am working on a simple gimbal camera and when I perform the related camera rotation, the sliding occurs in the related FOV because it provides a dynamic movement according to my intersection on the earth. If you help me ,I would be pleased. My basic algorithm for camera zoom void Sim::Manager::BCameraManager::update_camera_zoom(){ mGimbal.camera->setFov(params.maxFov); float tcurrent_zoom_factor = params.maxFov/params.fov; //these are fov and calculated correctly //float z_far = mGimbal.camera->getZFar(); //float z_near = mGimbal.camera->getZNear(); Unigine::Math::vec3 direction = mGimbal.camera->getWorldDirection(Unigine::Math::AXIS_NZ); Unigine::Math::Vec3 p1 = mGimbal.camera->getWorldPosition(); Unigine::Math::Vec3 p2 = p1 + Unigine::Math::Vec3(direction * 20000.0); auto intersection = Unigine::WorldIntersection::create(); // mGimbal.camera->setViewportMask(0x400); auto res = Unigine::World::get()->getIntersection(p1, p2, 0x00000400, intersection);//4 Landscape // mGimbal.camera->setViewportMask(0x1); Unigine::Math::Vec3 point; if (res) { point = intersection->getPoint(); camzoomparam.distance = length(point - p1); //Here i get intersection between gimbal cam and landscape qDebug()<<"intersection @"; } else { point = p2; qDebug()<<"No intersection!"; } camzoomparam.distance -= camzoomparam.distance/tcurrent_zoom_factor; //Zooming operation for gimbal cam position mGimbal.camCurrentPoint = p1+ Unigine::Math::Vec3(direction * camzoomparam.distance); mGimbal.camera->getCamera()->setPosition(mGimbal.camCurrentPoint);//Here i apply cam position therefore it gives accuracy like a manual zoom operation . //The Only Problem is , intersection point is always change(because landscape point of intersection is changing when i turn gimbal cam to another point) //So I have to keep related cam fov when i move gimbal to right,left and up,down //But i really have no idea } Thank you in advance Edited March 12, 2020 by burakdogancay Link to comment
burakdogancay Posted March 13, 2020 Author Share Posted March 13, 2020 Any idea, please ... Link to comment
