dongju.jeong Posted March 4, 2020 Share Posted March 4, 2020 (edited) What factors determine the pivot position of the top node(dummy node) when importing an FBX? The top node shown in the photo was not in the Max model. Edited March 4, 2020 by dongju.jeong Link to comment
silent Posted March 4, 2020 Share Posted March 4, 2020 dongju.jeong The root node may be added on different stages: FBX Export from 3ds Max. In that case pivot position is calculated somehow by 3ds Max - you can experiment with different export options to see the difference. Import. The behavior itself is controlled by FBX SDK. We are setting SetRotationPivotAsCenterRecursive mode. Please, keep in mind that you can see the actual pivot location only when you switch selection mode to Local -> Pivot: https://developer.unigine.com/en/docs/2.10/editor2/select_position_nodes/#pivot_point Thanks! 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
