LOD , effected by camera FOV
How do I get the LOD of the terrain to be affected by the value of the camera's FOV?
Currently, the FOV seems to vary depending on  just the distance of the camera.
dongju.jeong
What is the typical zoom level you want to achieve? ObjectTerrainGlobal has some limitations on multiple cameras and zoom levels.
These limitations were eliminated with new Landscape Terrain object: https://developer.unigine.com/en/docs/2.10/objects/objects/terrain/landscape_terrain/
Which one you are using in your project? Do you consider upgrade to the latest Landscape Terrain for this project?
I need x8~ x10 zoom level.
Currently I have version 2.9.
I am using a georeferenced terrain made from actual local data(ecw files).
(To use Cigi,Ig api)
Does your mean that the problem has been updated in 2.10?
in 2.10,
If I use my data to make an ObjectLandscapeTerrain instead of ObjectTerrainGlobal , does it solve the problem?
Quote
Hello! this is not a very large zoom. have you tried changed render_distance_scale? maybe this will be enough.
if this is not enough you can try one trick: translate player modelview forward, but projection backward
zoom_camera->setModelview(inverse(inverse(main_mode_view) * translate(Vec3(0,0, -distance)))); // translate modelview forvard
zoom_camera->setProjection(perspective(main_fov/zoom_factor, 1.0f, distance + 0.1, z_far) * translate(vec3(0, 0, -distance))); // translate projection matrix backward
This trick affects up to the haze.
render->setDistanceScale()  I am not sure what is changing
render->setDistanceScale(zoom_factor) // or zoom_factor * 3 - check another param, what better.
hmm.. may be you can show some video/screenshot with haze affects?
this is just Fov  set 6 [ for x10 -> 60 / 10]
this is Fov set 60 and
camera->setModelview(Math::inverse(Math::inverse(camera->getModelview()) * Math::translate(Vec3(0, 0, -5000))));    // I'm not sure I        should set the distance 5000.
camera->setProjection(perspective(60 / 10, 1.f,  0.01, 20000) * translate(vec3(0, 0, -5000)));
The distant landscape is also a little different. Mountain not  rendered a little.
Edited by dongju.jeong
Regarding the terrain culling artifacts, I guess you need to tune  culling parameters, such as:
  • Frustum Culling Padding
  • Subpixel Polygons Reduction
  • Back Face Culling
  • Oblique Frustum Culling
in the terrain_global_base material: https://developer.unigine.com/en/docs/2.9/content/materials/library/terrain_global_base/#parameters
You need to experiment a little to find the best ones for your current terrain.
