fabre.cedric Posted February 19, 2020 Share Posted February 19, 2020 Hello, I have searched in the doc and the forum but haven't found anything about that. For the moment, I initialize the engine in QT viewport without problem but, I would like to know if there is a way to : Initialize engine Load a mesh and his material Render the scene Without any script or .world or .usc file ? I think I don't understand how this engine work... thanks. Link to comment
fox Posted February 20, 2020 Share Posted February 20, 2020 Hi Cedric, A script is optional, but the point is that you actually need a world. You can check out the ViewportQt sample included in the SDK (In the SDK Browser open Samples -> 3rd party -> ViewportQt ) to familiarize yourself with the workflow. See the SystemLogic::init() method in the AppSystemLogic.cpp file of this sample: int AppSystemLogic::init() { // here we load a world-file named "viewport_world.world" (you can replace it with an empty world if you wish) Unigine::Console::run("world_load data/viewport_world"); return 1; } In order to manage the logic of your world you'll need an instance of an AppWorldLogic class inherited from the Unigine::WorldLogic. As for loading meshes, creating objects, etc., you can replace the contents of the ViewportQt.cpp file in the sample with the following code (with comments): // Qt #include "MainWindow.h" #include <QApplication> #include <QDesktopWidget> // Unigine #include "AppSystemLogic.h" #include <UnigineEngine.h> // including necessary headers #include <UnigineWorld.h> #include <UnigineLights.h> #include <UnigineGame.h> #include <UnigineMaterials.h> #include <UnigineObjects.h> // Common #include "GLAppQt.h" #ifdef _WIN32 #include "D3D11AppQt.h" #endif enum { RENDER_OPENGL, RENDER_D3D11, }; int get_render_api() { #ifdef _WIN32 const int DEFAULT = RENDER_D3D11; #else const int DEFAULT = RENDER_OPENGL; #endif QStringList arguments = qApp->arguments(); int index = arguments.indexOf("-video_app"); if (index == -1) return DEFAULT; if (index + 1 >= arguments.size()) { arguments.removeAt(index); return DEFAULT; } if (arguments[index + 1] == "opengl") return RENDER_OPENGL; #ifdef _WIN32 if (arguments[index + 1] == "direct3d11") return RENDER_D3D11; #endif return DEFAULT; } // injecting namespaces using namespace Unigine; using namespace Unigine::Math; // declaring our World Logic class implementing the logic of our world class AppWorldLogic : public Unigine::WorldLogic { public: AppWorldLogic() {} virtual ~AppWorldLogic() {} int init() override { // creating a world light source an setting its color to white LightWorldPtr thesun = LightWorld::create(Math::vec4(1.0f, 1.0f, 1.0f, 1.0f)); // setting light source's parameters (intensity, disable angle, scattering type, name and rotation) thesun->setName("Sun"); thesun->setDisableAngle(90.0f); thesun->setIntensity(1.0f); thesun->setScattering(LightWorld::SCATTERING_SUN); thesun->setWorldRotation(Math::quat(86.0f, 30.0f, 300.0f)); // creating a box (ObjectMeshDynamic node) MeshPtr mesh = Mesh::create(); mesh->addBoxSurface("box_surface", Math::vec3(1.5f, 1.5f, 1.5f)); ObjectMeshDynamicPtr my_mesh = ObjectMeshDynamic::create(mesh); MeshPtr mesh2 = Mesh::create(); // loading a mesh from an fbx model imported to the data/fbx/ folder using the Editor mesh2->load("data/some_mesh.mesh"); //create another ObjectMeshStatic node from the loaded mesh ObjectMeshStaticPtr my_mesh2 = ObjectMeshStatic::create(mesh2); // getting the base mesh_base material to inherit from MaterialPtr mesh_base = Materials::findMaterial("mesh_base"); // creating a new child material of the mesh_base named "my_mesh_base0" MaterialPtr my_mesh_base = mesh_base->inherit("my_mesh_base0"); // setting the albedo color of the material to red my_mesh_base->setParameterFloat4("albedo_color", Math::vec4(255, 0, 0, 255)); // assigning a "my_mesh_base0" material to the surface 0 of the my_mesh ObjectMeshDynamic node my_mesh->setMaterial("my_mesh_base0", 0); // assigning a "my_mesh_base0" material to all surfaces of the my_mesh2 ObjectMeshDynamic node my_mesh2->setMaterial("my_mesh_base0", *); // creating a new PlayerSpectator instance PlayerSpectatorPtr playerSpectator = PlayerSpectator::create(); // setting necessary parameters: FOV, ZNear, ZFar, view direction vector and position. playerSpectator->setFov(90.0f); playerSpectator->setZNear(0.1f); playerSpectator->setZFar(10000.0f); playerSpectator->setViewDirection(Math::vec3(0.0f, 1.0f, 0.0f)); playerSpectator->setWorldPosition(Math::Vec3(-1.6f, -1.7f, 1.7f)); // setting the player as a default one via the Game singleton instance Game::setPlayer(playerSpectator); //Unigine::World::loadNode("data/material_ball.node"); Unigine::World::loadNode("data/some_node.node"); return 1; } int shutdown() override { return 1; } int update() override { return 1; } }; int main(int argc, char *argv[]) { // Qt part QApplication app(argc, argv); MainWindow window; // UnigineApp AppQt *widget = NULL; if (get_render_api() == RENDER_OPENGL) widget = new GLAppQt(&window); else { #ifdef _WIN32 widget = new D3D11AppQt(&window); #endif } // UnigineLogic AppSystemLogic system_logic; AppWorldLogic world_logic; int unigine_argc = argc + 2; char **unigine_argv = new char *[unigine_argc]; for (int i = 0; i < argc; i++) { unigine_argv[i] = new char[strlen(argv[i])]; strcpy(unigine_argv[i], argv[i]); } unigine_argv[argc] = strdup("-data_path"); unigine_argv[argc + 1] = strdup("./"); // local path Unigine::EnginePtr engine(UNIGINE_VERSION, widget, unigine_argc, unigine_argv); engine->addSystemLogic(&system_logic); // adding our world logic engine->addWorldLogic(&world_logic); window.setWindowTitle("main_qt"); window.setCentralWidget(widget); window.move((QApplication::desktop()->screen()->width() - window.width()) / 2, (QApplication::desktop()->screen()->height() - window.height()) / 2); window.show(); return app.exec(); } You can learn other things from our Quick Start Tutorial. Hope this helps! Thanks! Link to comment
fabre.cedric Posted February 20, 2020 Author Share Posted February 20, 2020 Yes, in meantime I have found the solution and my problem came from the initialization of QT on the main window that appear always black with Unigine evaluation logo. In the second and third viewport there is no problem, my scene appear correctly. I'm really surprised by the render quality. That's really incredible ! Thanks for your answer. Link to comment
fox Posted February 21, 2020 Share Posted February 21, 2020 Glad you like it! You're welcome! Link to comment
fabre.cedric Posted February 21, 2020 Author Share Posted February 21, 2020 Maybe have you got some idea why the main window stay black ? I can draw the profiler with Fps. The profiler draw : Triangles All : 0 Triangles Shadows : 0 Triangles viewport : 0 If I open a new viewport the render appear OK in the viewport. I use the sample code for QT integration. Maybe a flag or other ? Thanks. Link to comment
fabre.cedric Posted February 21, 2020 Author Share Posted February 21, 2020 I have found where is the problem. I don't use the Game class with spectator. I use camera.... Link to comment
