PhysicalTrigger functions question
In Entercallback function, Is there a way to get contactpoint directly? ( using a way trigger->getContactPoint(int contact) , body->getContactPoint(int num) or another )
Can I get the contact number of the current contact right away?
and Does the Entercallback function run only once when contacted moment, and getNumContacts() continue to have the same return value while the contact continues?
Edited by dongju.jeong
Could you please specify what do you mean by "get contactpoint directly"? I'm not sure if get you right.
Quote
As for getting a contact number, how do you plan to use this number? The point is that a contact can be handled by any of the bodies that participate in it. If the contact is assigned to and handled by another body (it's random), the number of contacts for the current body is not incremented. So, if you've got two bodies having a contact, they will not have "copies" of this particular contact with the same number, in fact, only one of the bodies will have it, the one that handles it.
Quote
Yes.
Spoiler
//callback function (physical trigger)
void Haptic::trigger_enter(BodyPtr body)
	ObjButton* bt = getComponent<ObjButton>(body->getObject()->getNode());
	if (bt)
		EnterButtonBodys.push_back(bt);
      // +I want to get the current contact number or the contact point in here.
Hi Dongju,
You can get contact points for the entering body like this:
	if (bt)
			Vector<int> contact_numbers;
			int num_body_shapes = body->getNumShapes();
			int num_contacts = trigger->getNumContacts();
			// checking which of the shapes collided with the trigger
			// belong to the currently entering body (a body can have several shapes)
			// and remembering contact numbers
			for (int i = 0; i < num_contacts; i++)
				for (int j = 0; j < num_body_shapes; j++)
					if (trigger->getContactShape(i) == body->getShape(j))
						contact_numbers.append(i);
						break;
  			// printing all contact points detected for the body
			for (int ci = 0; ci < contact_numbers.size(); ci++)
				vec3 p = trigger->getContactPoint(ci);
				Log::message("\nBody contact point [%d]: (%f, %f, %f)", ci, p.x, p.y, p.z);
Hope this helps!
