Sign in to follow this
import FBX issue
When importing, 2 surface UH-60L_C2 is created and the same material is used.
Material #6784 uses the same texture used by the material in UH-60L_C2.
Why is it being imported so inefficiently?
When the "Merge Surfaces by material" setting is enabled, the editor turns off while it is being imported.
I want to combine the surface that uses the same Mertreal.
For example, I hope that Material #6784 and two UH-60L_C2 will be formed as one UH-60L_C2.
What is wrong with the FBX file? Or is there a solution in the Editor?
UH-60L_C9_Alb.zip
Edited by dongju.jeong
Share this post
Link to post
dongju.jeong
Quote
  Material #6784 uses the same texture used by the material in UH-60L_C2. Why is it being imported so inefficiently?
The surfaces list are being created from the topology that artists created in DCC tool (assuming that in your case it is 3ds Max), so it's being split just as it was designed.
Quote
The surface names are identical because in original FBX file you have materials with different IDs, but identical names (these names you are seeing in the surface list). Technically, these materials are unique because they have different IDs inside 3ds Max.
In your case surfaces can't be automatically combined on import with Merge Surfaces by Material option, because it works only with truly identical materials (from original FBX file).
Merge Similar Materials option should in theory merge all the 3 materials into a 1, but in my tests it merges only uh-60* materials into a single file. I will try find out if this bug or not and report back.
Please, also, keep in mind that when you will merge surfaces you will no longer able to control the individual parts (for example, switches that would be merged with dashboard).
Quote
 What is wrong with the FBX file? Or a solution within the Unigine Editor?
So right now the only a single option is available for you (if you really want to use a single materials instead of 3) is to edit the model in DCC tool and get rid of overlapping names for materials with different IDs.
Quote
It's definitely a bug, I can reproduce it in 2.10 SDK as well. Will try to fix in the upcoming 2.11 update. Thanks for the test FBX, it's very helpful.
Share this post
Link to post
