monitorius Posted June 23, 2011 Share Posted June 23, 2011 JointHinge::getCurrentAngularVelocity() method always returns zero if one of the joined bodies is BodyDummy, regardless of real (visible) angular velocity Link to comment
manguste Posted July 1, 2011 Share Posted July 1, 2011 getCurrentAngularVelocity() is valid only if both bodies are of BodyRigid type. In all other cases 0 is returned. But as BodyDummy is always immovable, you can get the same result by the following code: // BodyDummy is the second body dot(getWorldAxis(),rigid_body.getAngularVelocity()); Invert angular velocity of the rigid body in case BodyDummy is the first of two bodies that the joint connects together. Link to comment
monitorius Posted July 4, 2011 Author Share Posted July 4, 2011 It's not a problem for me, I've already changed the getCurrentAngularVelocity() code. But it's still a bug, and it looks like it should be fixed in Unigine. If there are rigid and dummy bodies, connected using JointHinge, and angular motor is on, THERE IS non-zero angular velocity, and joint should return it's value, don't it? 1 Link to comment
manguste Posted July 4, 2011 Share Posted July 4, 2011 I'll pass this along to our developers, no doubt :) Link to comment
