mohamed.irshad.k Posted June 22, 2011 Share Posted June 22, 2011 I have the below script in my world.cpp // Unigine script namespace Widgets { WidgetButton CreateButton() { Gui gui = engine.getGui(); WidgetButton widgetButton = new WidgetButton(gui); gui.addChild(widgetButton, GUI_ALIGN_EXPAND); widgetButton.setCallback(GUI_CLICKED, "Widgets::Button_Clicked"); return widgetButton; } void Button_Clicked() { // Do stuff.... } } I call this CreateButton funtion from C++: engine->runWorld("Widgets::CreateButton"); Unigine crashes at the line: widgetButton.setCallback(GUI_CLICKED, "Widgets::Button_Clicked"); I tried push/popWorld, but didn't help. Link to comment
Guest mrred Posted June 27, 2011 Share Posted June 27, 2011 I have the below script in my world.cpp // Unigine script namespace Widgets { WidgetButton CreateButton() { Gui gui = engine.getGui(); WidgetButton widgetButton = new WidgetButton(gui); gui.addChild(widgetButton, GUI_ALIGN_EXPAND); widgetButton.setCallback(GUI_CLICKED, "Widgets::Button_Clicked"); return widgetButton; } void Button_Clicked() { // Do stuff.... } } I call this CreateButton funtion from C++: engine->runWorld("Widgets::CreateButton"); Unigine crashes at the line: widgetButton.setCallback(GUI_CLICKED, "Widgets::Button_Clicked"); I tried push/popWorld, but didn't help. Please, attach your log.html file located at the bin directory of project and your script so that we could reproduce and fix this. Link to comment
mohamed.irshad.k Posted June 28, 2011 Author Share Posted June 28, 2011 Please, attach your log.html file located at the bin directory of project and your script so that we could reproduce and fix this. Please find attached the log.html, world.cpp and world.world files. log.html world1.cpp world1.world Link to comment
Guest mrred Posted June 29, 2011 Share Posted June 29, 2011 As a temporal workaround try commenting this line return widgetButton; If You will still experience crash, please, post here or send for support@unigine.com a minimal version of your C++ Application so that we could reproduce this issue and find a solution. Link to comment
mohamed.irshad.k Posted June 29, 2011 Author Share Posted June 29, 2011 I tried your workaround, but still the program is crashing. I have mailed a sample project to support@unigine.com for reproducing the issue. Link to comment
Guest mrred Posted June 29, 2011 Share Posted June 29, 2011 I tried your workaround, but still the program is crashing. I have mailed a sample project to support@unigine.com for reproducing the issue. Thank You, we'll try to reproduce this issue now. I will contact you soon. Link to comment
Guest mrred Posted June 29, 2011 Share Posted June 29, 2011 We found the source of this issue. It is this line that makes unigine crash: widgetButton.setCallback(GUI_CLICKED, "Widgets::Button_Clicked"); Thank You for pointing this bug for us. We will fix it in the next SDK release approximately in a month. Link to comment
mohamed.irshad.k Posted June 30, 2011 Author Share Posted June 30, 2011 Thanks mrred. For the time being, is there any work around for this? In our project, we need to set the callback from C++ side. Link to comment
Guest jashik Posted July 1, 2011 Share Posted July 1, 2011 You can use deferred execution to make a callback for widget. Example: [C++: main.cpp] #include <Unigine.h> #include <UnigineInterpreter.h> using namespace Unigine; int main(int argc, char * argv[]) { Engine * engine = Engine::init(UNIGINE_VERSION, argc, argv); int count = 5; // For delay Variable command("CreateButton"); while (!engine->isDone()) { if(count == 0) { engine->runWorld("addDeferredExecution",command); count = -1; } else if(count > 0) { count--; Log::warning("count = %d \n",count); } engine->update(); engine->render(); engine->swap(); } engine->shutdown(); return 0; } [unigineScript: world1.cpp] /* */ string deferred_executions[0]; /* */ int init() { engine.game.setPlayer(new PlayerSpectator()); return 1; } /* */ int shutdown() { return 1; } /* */ int update() { if(deferred_executions.size() > 0) { forloop(int i = 0; deferred_executions.size()) { string command = deferred_executions[i]; log.message("call command '%s'\n",command); engine.world.call(deferred_executions[i]); } deferred_executions.clear(); } return 1; } /* */ void addDeferredExecution(string command) { log.message("add command '%s'\n",command); deferred_executions.append(command); } /* */ void CreateButton() { Gui gui = engine.getGui(); WidgetButton widgetButton = new WidgetButton(gui); widgetButton.setCallback(GUI_CLICKED,"call_back"); gui.addChild(widgetButton, GUI_ALIGN_LEFT); log.message("CreateButton \n"); } /* */ void call_back() { engine.console.print("In call_back()\n"); } Link to comment
mohamed.irshad.k Posted July 1, 2011 Author Share Posted July 1, 2011 That did the trick! Thanks Jashik. Link to comment
