ashwin.sudhir Posted June 21, 2011 Share Posted June 21, 2011 This snippet from our code shows how we use the return value of runSystem() to return a vec3 from UnigineScript Unigine::Variable var = GLib::GetSingletonImpl()->GetEngine()->runSystem( "Model::GetPosition", Unigine::Variable(m_idNode) ); Unigine:::vec3 vPos = var.getVec3() etc. and this works just fine But this fails when we try to return a Node through a Unigine::Variable Unigine::Variable var = GLib::GetSingletonImpl()->GetEngine()->runSystem( "Model::SetColorScale", Unigine::Variable(m_idNode), CGLibHelper::CVector3DToVariable(vColor) ); followed by var.getNode() causes an access violation. Is returning a NodePtr through runSystem's return value not supported? UnigineScript =================== Node SetColorScale(int idNode, vec3 vColor) { Node node = engine.world.getNode(idNode); Object obj = node_cast(node); if( obj.getNumSurfaces() > 0 ) obj.setMaterialParameter("color_scale", vec4(vColor, 0.f), 0); return node; } Thanks, Ashwin. Link to comment
Guest anet Posted June 22, 2011 Share Posted June 22, 2011 Add Engine::pushSystem() before calling runSystem() and Engine::popSystem() after it. It will set appropriate runtime. See details here (Create Variable in Extern Function section) Link to comment
ashwin.sudhir Posted June 22, 2011 Author Share Posted June 22, 2011 Add Engine::pushSystem() before calling runSystem() and Engine::popSystem() after it. It will set appropriate runtime. See details here (Create Variable in Extern Function section) Thanks! that did it. Link to comment
