Deterministic move of particles on two connected computers
we are starting a particle system on two different computers which have synchronized positions of the emitter with timestamps.
How can we make sure that all emitted particles get the same position/orientation/contact points with colliding objects, because we are observing different values for them?
Is there a seed which can be set to get the same results on both machines?
Thanks,
Sebastian
Thanks,
we did set the same seed for the particle systems, spawning looks good at the beginning but the particles get fast out of sync then. Are there any other settings we have to manage?
Regards,
Sebastian
Right now particles sync solution works with short duration effects (like explosions). Long duration simulations may cause desynchronization. Unfortunately, we didn't find a proper solution for that task yet.
You can improve this behavior by force updating of particles nodes (so it would continue simulation outside of the viewing frustum).
Could you please tell us what kind of real-world effect you are currently trying to simulate?
We try to synchronize different type of water/smoke jets and big smoke clouds, which have a longer lifetime. We observe desynchronization while Emitter position and orientation is not changing and all particles are in viewing frustum.
By the way, how can we force updating of particle nodes outside of the view frustum?
Thank you.
  • 5 months later...
Hello Unigine,
are there any updates on this?
I have read it has been refactored in 2.10 but I have not found any api to get those results.
On 12/25/2019 at 6:15 PM, fox said:
Particle Systems Update
Refactored Particle Systems have got more deterministic behavior significantly improving image consistency for multi-channel rendering use cases. So, when a particle is spawned on one IG/PC, it can travel to another screen (a view from another IG/PC) seamlessly, which is very important for multi-channel image generators.
More Rendering Improvements
In 2.10 we added 3 new API methods for particles synchronization:
To save particles you need to set mode to MASTER, then take the data. To restore their state you need to set mode to SLAVE, then use applySyncData.
Have you tried this?
I have more questions:
1. Is there any information which states gets synchronized when taking and applying data?
2. Is emitter enabled/disabled one that gets synchronized?
These methods synchronize particles only. When you're taking the data you get position, velocity, angle, radius, grow, life, texcoord and number of hidden parameters that we need to synchronize each particle. Emitter is not taken into account.
Emitter is ignored with takeSyncData. If you wanted to disable other emitter with applySyncData it wouldn't work.
Thanks.
On 11/5/2019 at 5:47 AM, binstream said:
We are improving particle systems now (control by splines, etc.) and we'll see if this can be improved now.
Is there already an update for this? Has the idea been rejected or is it still being pursued?
Thanks,
Sascha
15 hours ago, binstream said:
Working on it for the 2.12 release, looks good so far. Was not ready for 2.11 though.
Thank you, for the update - hope to see it soon.
