Walters.Robert Posted October 11, 2019 Share Posted October 11, 2019 I randomly started getting this error late yesterday. I'm stumped as to what is causing it. I've tried reverting my code to before I started receiving the error and it still pops up. I'm running 2.9.0.2 Link to comment
morbid Posted October 13, 2019 Share Posted October 13, 2019 Hello Robert, By randomly you menat there's no any pattern? Usually pointer errors occurs when some node or asset you're reaching via code is miising. Have you made any chabges to the scene recently? Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
Walters.Robert Posted October 14, 2019 Author Share Posted October 14, 2019 Randomly as in I couldn't see any reason for the error, however, the behavior was consistent in that it crashed every single time. I had moved a node to act as a child in another node but even after reverting back to the original scene I kept receiving the error. I ended up reverting to a previous version of the project that I had as a backup. If it happens again and I can pin-point it I'll let you know. Link to comment
aleksandr.malkov Posted October 14, 2019 Share Posted October 14, 2019 Hello Robert! Try to recall the objects (inherited from Smart Ptr) that you added in the code, probably some of them were incorrectly initialized. Link to comment
robert.walters Posted January 28, 2020 Share Posted January 28, 2020 So I've created an additional world with a different terrain to load in my simulator (running 2.9.0.2). When I run the original world in either master or slave mode no problem. When I run the new world in master mode no problem. When I run the new world in slave mode I'm getting the pointer error. Unigine fatal error: c:\unigine sdk browser\sdks\sim_per_channel_windows_2.9.0.2\include\unigineptr.h:54: Assertion: 'pointer && "Unigine::Ptr::operator->(): pointer is NULL"' I'm selecting the world to load through the .bat file @echo off chcp 65001 setlocal EnableDelayedExpansion set app=bin\GoldBeach_x64.exe start %app% -system_script core/systems/syncker/unigine.cpp -sync_master 0 -sync_broadcast_address 128.61.191.255 -sync_slave_name "instruments" -video_app auto -video_vsync 0 -video_refresh 0 -video_mode -1 -video_resizable 1 -video_fullscreen 2 -video_width 1920 -video_height 1080 -video_debug 0 -video_gamma 1.000000 -sound_app auto -data_path "../data/" -engine_config "../data/unigine.cfg" -extern_plugin "OpenFlight,FbxImporter,CadImporter,GLTFImporter,Syncker,AppEasyBlend" -calibration_file "C:\Program Files\Scalable Display\DEI\LocalCalibration\ScalableData.ol" -console_command "config_readonly 1 && world_load \"LA\"" Link to comment
silent Posted January 28, 2020 Share Posted January 28, 2020 Hi Robert, Have you tried to build debug version of your app and do a step-by-step debugging in IDE? If you can't find the root cause, could you please send us your project (data and source directories) with a build instructions and reproduction steps? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
