roberto.voxelfarm 0 Share Posted October 8, 2019 (edited) Hello Unigine ... I have 3 problems using SSLSocket Using Unigine script creating a client it don't pass the Handshake with a RSS Feed server The plugin sample ssl_socket_01.cpp, is using tls 1.0 or 1.1 that are deprecable, I try to load my own private key and don't load. How I can use this plugin from C++ if I don't found the interface?. Expanding the questions.... Problem 1 I trying to create a single client and down some RSS feed sample. This client connect but fail on the handshacke. int init() { #ifdef HAS_SSL_SOCKET log.message("ssl socket\n"); socket = new SSLSocket(); // https://www.feedforall.com/sample.xml socket.open("www.feedforall.com", 443); if (socket.connect()) { log.message("Is Connected\n"); if(socket.getHandshake()) { log.message("Handshake OK\n"); stream = socket.getStream(); if (stream!=NULL) { log.message("Stream is OK\n"); // socket.block(); stream.printf("GET /sample.xml HTTP/1.1\r\nHost: www.feedforall.com\r\nUser-Agent: Unigine\r\n\r\n"); if (stream.isAvailable()) { log.message("isAvailable OK\n"); } else { log.message("isAvailable not data\n"); } log.message(stream.gets()); } else { log.message("Stream is NULL"); } } else { log.message("Handshake FALSE\n"); } } else { log.message("Not is Is Connected\n"); } #else log.message("SSLSocket plugin is not loaded"); #endif return 1; } Problem 2 For Other place I test your server application and this work. But I used your Private key and certificate. The browser says that is using TLS 1.0 or TLS 1.1 that are deprecable. Then I try to use my own web site private key and certificate. This load the certificate correctly but the Private key fail loading that. void create() { socket = new SSLSocket(); socket.open(4433); socket.bind(); socket.listen(10); socket.nonblock(); socket.load(SSL_SOCKET_RSA_KEY,fullPath("ssl/lynza/private_key.pem")); // Fail load this, this load fine with OpenSSL socket.load(SSL_SOCKET_X509_CERT,fullPath("ssl/lynza/certificate.pem")); // certificate load fine. //socket.load(SSL_SOCKET_RSA_KEY,fullPath("ssl/private_key.pem")); //socket.load(SSL_SOCKET_X509_CERT,fullPath("ssl/certificate.pem")); } Unigine~# config_readonly 1 && world_load "SSLServerTest" Script loading "core/unigine.usc" 9ms Loading "core/locale/unigine.locale" dictionary 1ms Script loading "SSLServerTest.cpp" 9ms World loading "SSLServerTest.world" 102ms SSLSocket::load(): can't load certificate from "ssl/lynza/private_key.pem" file -269 ----Load cache textures---- Cache textures loaded 94 (62ms) Problem 3 /Roberto Edited October 9, 2019 by roberto.voxelfarm spelling Link to post
morbid 197 Share Posted October 9, 2019 Hello Roberto, 10 hours ago, roberto.voxelfarm said: Problem 1 You need to load the certificate right after you've created SSLSocket. Please, check how it was made in the SDK sample ssl_socket_00.cpp. 10 hours ago, roberto.voxelfarm said: Problem 2 Error 269 is an SSL one. I can't give you more info based on the description. Looks like the issue is on the certificate side. How exactly did you make it? 12 hours ago, roberto.voxelfarm said: Problem 3 There's no interface for C++, only UnigineScript available. As a workaround you can create header and use it in your own app. Thanks. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to post
roberto.voxelfarm 0 Author Share Posted October 9, 2019 (edited) For problem 1, I make many test, one of that was load certificate too. and continue fail the handshake for problem 2, you can use https://www.sslforfree.com/ with this site, you can generate a valid certificate free for 3 months and use this for the test. Problem 1 code int init() { #ifdef HAS_SSL_SOCKET log.message("ssl socket\n"); socket = new SSLSocket(); int v = socket.load(SSL_SOCKET_X509_CACERT,fullPath("pem/certificate.pem")); log.message("Load certificate %i\n", v); //socket.nonblock(); // https://www.feedforall.com/sample.xml socket.open("www.feedforall.com", 443); if (socket.connect()) { log.message("Is Connected\n"); if(socket.getHandshake()) { log.message("Handshake OK\n"); stream = socket.getStream(); if (stream!=NULL) { log.message("Stream is OK\n"); // socket.block(); stream.printf("GET /sample.xml HTTP/1.1\r\nHost: www.feedforall.com\r\nUser-Agent: Unigine\r\n\r\n"); if (stream.isAvailable()) { log.message("isAvailable OK\n"); } else { log.message("isAvailable not data\n"); } thread("read_data"); log.message(stream.gets()); } else { log.message("Stream is NULL"); } } else { log.message("Handshake FALSE\n"); } } else { log.message("Not is Is Connected\n"); } #else log.message("SSLSocket plugin is not loaded"); #endif return 1; } /roberto Edited October 9, 2019 by roberto.voxelfarm Link to post
