content5 Posted September 17, 2019 Posted September 17, 2019 As we have made one flag animation in maya with the use of joint and vertex backed animation.When we import this animation in Unigine SDK version 2.5 the mesh object of flag is not coming properly. we follow below method of animation. https://www.youtube.com/watch?v=PcXNVZexVzc kindly check attached Maya 2016 file(.ma) and FBX file with this mail kindly check and let us know the solution, Regards Himanshu Thakor & Dhruv Kadivar Monarch SoftTech LLP MUMBAI INDIA Flag_Maya.zip
silent Posted September 18, 2019 Posted September 18, 2019 content5 Thanks for the test model, we will take a closer look into this issue next week. More likely fix for this issue will be available in 2.10 SDK update. Also, we would not be able to provide a patch for 2.5 version. I can send you *.mesh + *.anim after this issue will be resolved in our internal builds. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
content5 Posted September 18, 2019 Author Posted September 18, 2019 Thanks Dear Awaiting for Your replay..
silent Posted September 23, 2019 Posted September 23, 2019 We've checked your FBX file and found that you have 1 surface with more that 1000 bones assigned. That will not work directly in UNIGINE because we have following limitations on bones animation. For skinned mesh: The maximum number of bones per surface is equal to 128. Each vertex can have up to 4 bones assigned to it. So in your case you can try to: Reduce the overall bones number (128 will be enough to get the same animation quality). OR Increase number of surfaces (just split your mesh to a set of squares and assign new materiel to each square). That would split your mesh into the surfaces on import and overall number of bones per surface will be lower. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
