aka3301 Posted September 6, 2019 Share Posted September 6, 2019 I try to create a simple box with following code, but the rendering result was not as expected. Any idea to solve the problem? Thanks in advance. int AppWorldLogic::init() { // Write here code to be called on world initialization: initialize resources for your world scene during the world start. MeshPtr box1 = Mesh::create(); box1->addSurface("box1"); box1->addVertex(vec3(-0.5, -0.5, -0.5), 0); box1->addVertex(vec3(-0.5, -0.5, 0.5), 0); box1->addVertex(vec3(-0.5, 0.5, -0.5), 0); box1->addVertex(vec3(-0.5, 0.5, 0.5), 0); box1->addVertex(vec3(0.5, -0.5, -0.5), 0); box1->addVertex(vec3(0.5, -0.5, 0.5), 0); box1->addVertex(vec3(0.5, 0.5, -0.5), 0); box1->addVertex(vec3(0.5, 0.5, 0.5), 0); int index[36] = { 6,7,5,5,4,6,0,1,3,3,2,0,2,3,7,7,6,2,4,5,1,1,0,4,3,1,5,5,7,3,0,2,6,6,4,0 }; for (int i = 0; i < 36; i++) box1->addIndex(index[i], 0); box1->createBounds(0); box1->createTangents(0); box1->createNormals(0); ObjectMeshDynamicPtr BOX = ObjectMeshDynamic::create(box1); BOX->translate(Vec3(0, 0, 0.5)); BOX->release(); ... Link to comment
silent Posted September 6, 2019 Share Posted September 6, 2019 More likely it happens because createNormals generates smoothed normals. To avoid it you need to create normals on your side. Something like this: void create_box(MeshPtr &mesh, const char *name, const vec3 &size) { static const vec3 vertex[8] = { vec3(-0.5f, -0.5f, -0.5f), vec3(0.5f, -0.5f, -0.5f), vec3(-0.5f, 0.5f, -0.5f), vec3(0.5f, 0.5f, -0.5f), vec3(-0.5f, -0.5f, 0.5f), vec3(0.5f, -0.5f, 0.5f), vec3(-0.5f, 0.5f, 0.5f), vec3(0.5f, 0.5f, 0.5f), }; static const vec3 normals[6] = { vec3(1.0f, 0.0f, 0.0f), vec3(-1.0f, 0.0f, 0.0f), vec3(0.0f, 1.0f, 0.0f), vec3(0.0f, -1.0f, 0.0f), vec3(0.0f, 0.0f, 1.0f), vec3(0.0f, 0.0f, -1.0f), }; static const vec2 texcoords[4] = { vec2(1.0f, 1.0f), vec2(0.0f, 1.0f), vec2(0.0f, 0.0f), vec2(1.0f, 0.0f), }; static const int cindices[6][4] = { {3, 1, 5, 7}, {0, 2, 6, 4}, {2, 3, 7, 6}, {1, 0, 4, 5}, {6, 7, 5, 4}, {0, 1, 3, 2}, }; static const int indices[6] = { 0, 3, 2, 2, 1, 0, }; int surface = mesh->addSurface(name); for (int i = 0; i < 6; i++) { for (int j = 0; j < 6; j++) { int index = indices[j]; mesh->addVertex(vertex[cindices[i][index]] * size, surface); mesh->addNormal(normals[i], surface); if (i == 4) { mesh->addTexCoord0(vec2::ONE - texcoords[index], surface); mesh->addTexCoord1(vec2::ONE - texcoords[index], surface); } else { mesh->addTexCoord0(texcoords[index], surface); mesh->addTexCoord1(texcoords[index], surface); } } } mesh->createIndices(surface); mesh->createTangents(surface); mesh->createBounds(surface); } How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
aka3301 Posted September 9, 2019 Author Share Posted September 9, 2019 hi, silent Thanks for your response. I'll try. Link to comment
