adrian.licuriceanu Posted September 5, 2019 Share Posted September 5, 2019 Hello, We are in the process of migrating from 2.6 to 2.9 and one thing that I've noticed is that if I create a static mesh object from C++ code and add a surface to it (addEmptySurface) this comes as enabled = 0 by default, while previously was 1. This also seems to happen for mesh clusters. Can you confirm that this is the case and I am not missing some aspects? I didn't found this behaviour documented in migration notes in docs. Kind Regards, Adrian L. VStep Link to comment
silent Posted September 5, 2019 Share Posted September 5, 2019 Hi Adrian, Thanks for the pointing it out! More likely it was made intentionally, but we forget to mention this in the documentation. I will double-check this. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
silent Posted September 5, 2019 Share Posted September 5, 2019 Btw, could you please provide a code snippets that started to work in a different way after update? How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
adrian.licuriceanu Posted September 5, 2019 Author Share Posted September 5, 2019 Hi, For example: Unigine::ObjectMeshClusterPtr engCluster; engCluster = Unigine::ObjectMeshCluster::create(nullptr); engCluster->setMesh(mesh); After setMesh call I can see by debugging that Object::changed_mesh is called and the code enters in the if (id != -1) { s = surfaces[id]; } else where it takes the newly resized surfaces_new which is all filled with zero I guess, so the enabled is also zero. This, from what I can tell, used to be 1 in 2.5 version. As for ObjectMeshStatic, surface are indeed enabled when calling it by providing a mesh: Unigine::ObjectMeshStatic::create(mesh); But by calling: staticMesh = Unigine::ObjectMeshStatic::create(nullptr); staticMesh->addEmptySurface(nullptr, vertsNo, indsNo); and filling the data, will add the surface with enabled as zero (which again was 1 in 2.5 version). Kind Regards, Adrian L. Link to comment
silent Posted September 6, 2019 Share Posted September 6, 2019 Thanks for the additional code samples. Actually, that was a bug in 2.6: enabled flag contained some garbage: Right now it's filled with zero. Which value do you prefer that enabled flag should get after adding new surfaces for the mesh? Maybe we can fix this behavior in the upcoming 2.10 update. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
adrian.licuriceanu Posted September 6, 2019 Author Share Posted September 6, 2019 Hello, It doesn't matter for me what value it is by default, whatever makes sense for engine/other applications. I am currently making sure to enable/disable the surface after initiating it. Thank you for looking into this. Kind Regards, Adrian Link to comment
adrian.licuriceanu Posted September 10, 2019 Author Share Posted September 10, 2019 Hello, Related to this (side effect of the fix) I've also noticed that if I just call: mesh->setMaxVisibleDistance(some distance, surface index) so I can just have a mesh fade out at a certain distance, and don't also setup the min visible distance this remains zero now (since the surface data doesn't have garbage into it), as I approach the mesh its surfaces start to disappear. So now I also need to call: mesh->setMinVisibleDistance(-INFINITY, surface index) Maybe -inf should be default for min visible distance? Regards, Adrian Link to comment
silent Posted September 10, 2019 Share Posted September 10, 2019 That's interesting case, thanks! We will see how can we fix this. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
adrian.licuriceanu Posted September 12, 2019 Author Share Posted September 12, 2019 Ok, another side effect: If am using the above code (with addEmptySurface) sometimes, for first surface, I have the parent surface as zero. Shouldn't this be -1 as default? So then in RenderRenderer the following code: // asymmetry bounds else { // minimum bounds while (min_parent--) { if (min_surface_id != -1) { min_surface_id = object->getParent(min_surface_id); if (min_surface_id == -1) node = object; } else { if (node->getParent() == nullptr) { if (node->getPossessor()) node->getPossessor(); if (node->getParent() == nullptr) break; } node = node->getParent(); } } cycles with min_parent negatively for very long loops, probably resetting the int value back to zero due to overflow. So after addEmptySurface I have to call: if(staticMesh->getParent(surfIdx) == surfIdx) // Usually for S == 0 { staticMesh->setParent(-1, surfIdx); } Can you also verify this? Kind Regard, Adrian Link to comment
silent Posted September 13, 2019 Share Posted September 13, 2019 Sure thing! Thanks for the additional information. How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
adrian.licuriceanu Posted September 18, 2019 Author Share Posted September 18, 2019 Probably also related to this allocation data being all zero, my ObjectMeshCluster is no longer showing any data. The cluster, previously (in 2.5) working, is created from code with something like: engCluster = Unigine::ObjectMeshCluster::create(nullptr); engCluster->setMesh(engineMesh); Unigine::Vector<Unigine::Math::Mat4> insts; insts.resize(static_cast<int>(instancesNo)); for(size_t I=0; I<instancesNo; I++) { // Fill instances data with something like: insts[idx].setRotateZ(orientation); insts[idx].setColumn3(3, Unigine::Math::dvec3(pos.x, pos.y, pos.z)); } engCluster->createMeshes(insts); for(int S=0; S<engCluster->getNumSurfaces(); S++) { // Since most of the surface data is now zeroed upon release I have to: engCluster->setEnabled(1, S); engCluster->setParent(-1, S); engCluster->setViewportMask(mask); engCluster->setMinParent(1, S); engCluster->setMaxParent(1, S); engCluster->setMinVisibleDistance(-INFINITY, S); engCluster->setMaxVisibleDistance(INFINITY, S); engCluster->setMaterial(mat, S); } Any idea what can go wrong? I can debug and find out that ObjectMeshCluster::create_spatial is called (at createMeshes) and creates some nodes. Then update_culling is called. But no render surfaces are finally rendered for the cluster from what I can figure out. Can you point me in the right direction in the code where to breakpoint and check what may go wrong? Regards, Adrian L. Link to comment
cash-metall Posted September 19, 2019 Share Posted September 19, 2019 Hello! I checked your code, it works correctly for me - the cluster is displayed. there are some tips: 1. check if existing: -- engineMesh -- mat -- instancesNo > 0 -- mask correct with viewport. 2. engCluster->setViewportMask(mask, S); my code engCluster = Unigine::ObjectMeshCluster::create(nullptr); mesh = Unigine::Mesh::create("material_ball_2.mesh"); // my mesh MaterialPtr mat = Materials::get()->findMaterial("material_ball"); //my material engCluster->setMesh(mesh); int instancesNo = 10; //num instances Unigine::Vector<Unigine::Math::Mat4> insts; insts.resize(static_cast<int>(instancesNo)); for (int I = 0; I<instancesNo; I++) { // Fill instances data with something like: insts[I].setTranslate(Unigine::Math::dvec3(I, I, 0)); // ?? just diagonal } engCluster->createMeshes(insts); for (int S = 0; S<engCluster->getNumSurfaces(); S++) { // Since most of the surface data is now zeroed upon release I have to: engCluster->setEnabled(1, S); engCluster->setParent(-1, S); // engCluster->setViewportMask(~0, S); // set full vieport mask... or... it works for me without this line too. engCluster->setMinParent(1, S); engCluster->setMaxParent(1, S); engCluster->setMinVisibleDistance(-INFINITY, S); engCluster->setMaxVisibleDistance(INFINITY, S); engCluster->setMaterial(mat, S); } Link to comment
adrian.licuriceanu Posted September 19, 2019 Author Share Posted September 19, 2019 Hi and thank you for looking into this. In the end the error was quite stupid (I should have looked better). Seems that starting with Visual Studio 2017, somehow math.h was included last and INFINITY was there defined as #define INFINITY ((float)(_HUGE_ENUF * _HUGE_ENUF)) which is quite different than Unigine INFINITY. I've now used UNIGINE_INFINITY and all is fine. Btw, this is part of Unigine source code is not very safe in general (MathLib.h): // this is an internal include file // so we can redefine common constants here safely, for brevity in our own sources #ifdef INFINITY #undef INFINITY #endif ... Kind Regards, Adrian Link to comment
silent Posted September 20, 2019 Share Posted September 20, 2019 Quote Btw, this is part of Unigine source code is not very safe in general (MathLib.h): Agree, we will also take a look into this (but more likely after 2.10 release). Thanks for the update! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
adrian.licuriceanu Posted September 20, 2019 Author Share Posted September 20, 2019 I think I found (one of) the cause(s) for all these issues: when adding a new surface to an object you call Object::changed_mesh which does the following: Vector<Surface> surfaces_new; surfaces_new.resize(num_surfaces); for (int i = 0; i < num_surfaces; i++) { String name = getSurfaceName(i); Surface &s = surfaces_new[i]; if (id != -1) { s = surfaces[id]; } else { .... which is completely wrong if you don't have uniquely named surfaces (my case, where all the names where "", ie blank strings). So you get all new surfaces filled with zero datta (the newly allocated one) and then subsequently when the first surface data (again zero). You probably should have something like: int id = name.size() ? surfaces_name.findIndex(name) : -1; when searching for id. Anyway, it is completely unsafe to search by name of the surface as this is not guaranteed as unique / not blank at setSurfaceName !!! This was not the case for 2.5 version. In the case of the object cluster, you got visible now zero which is never touched for it and the clusters are nevere rendered. Regards, Adrian Btw, it is not very nice (from optimization point of view) that for each set (min/max distance, fade distances) you call update_lods() internally. Maybe you should have an startUpdateObject(), ..., endUpdateObject(), asserts if any set is called outside, assert if any other calls (like render) are done inside etc. Link to comment
silent Posted September 20, 2019 Share Posted September 20, 2019 Yep, more likely that's the one of the cases. We will for sure take a closer look in this code. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
adrian.licuriceanu Posted April 8, 2020 Author Share Posted April 8, 2020 (edited) Hello, I want to check about the status of this, since I've checked 2.10 and 2.11 source code and cannot find any fixed related to this. I am especially interested in void Object::changed_mesh() which doesn't take previous surfaces data if they are not named: int id = surfaces_name.findIndex(name); Surface &s = surfaces_new; if (id != -1) { s = surfaces[id]; } else { // create surfaces It seems to me that if you add surfaces from code, don't give them names, then at each new surface, you lost what you've previously setup for surfaces (as findIndex returns -1 for all previous ones). Do you have a solution for this? Or is (uniquely) naming the surface mandatory? Currently I have the following "fix" which works for me since I only append surfaces: int id; if(name.size() == 0) // Unnamed surface. { // Use the same index. We assume we add to the end... // But if this is a new surface, we must fill it with default data. if(i >= begin) id = -1; else id = i; } else id = surfaces_name.findIndex(name); // Old code as just: //int id = surfaces_name.findIndex(name); Regards, Adrian L. Edited April 8, 2020 by adrian.licuriceanu Link to comment
silent Posted April 9, 2020 Share Posted April 9, 2020 Hi Adrian, We've fixed couple of bugs (with INFINITY define and overall garbage that comes from constructor), but it looks like not all of them. If you can use workaround with non-empty name - it would be just great. We will check what else we can do here after 2.11 release. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
adrian.licuriceanu Posted April 13, 2020 Author Share Posted April 13, 2020 Hi Silent, Thank you, looking forward for the future fixes. Regards, Adrian Link to comment
adrian.licuriceanu Posted July 31, 2020 Author Share Posted July 31, 2020 (edited) Hi, I can see this (adding unnamed surfaces) fixed in 2.12, thanks. Will test if there are issues on our end but the fix seems about right. Edited July 31, 2020 by adrian.licuriceanu Message not clear enough. Link to comment
