ken.mayfield Posted June 15, 2011 Share Posted June 15, 2011 When I load a level using the following two commands, engine.world.getName() will return two different strings as a result. From script: engine.console.run("world_load Level_01"); engine.world.getName() returns the string "Level_01" From .bat file: -console_command "editor_quit && world_load _Game/worlds/Level_01" engine.world.getName() returns the string "_Game/worlds/Level_01" This seems inconsistent and has caused problems with a couple of our scripts. Link to comment
ulf.schroeter Posted June 16, 2011 Share Posted June 16, 2011 I wouldn't call it a bug. See details on UNIGINE file path handling here. Usage of consistent world filepath specification between internal/external scripts would solve your insonsistency problem. Link to comment
ken.mayfield Posted June 16, 2011 Author Share Posted June 16, 2011 I personally feel that there should be two different engine.world functions to support this... the first being engine.world.getPath() that would return "_Game/worlds/" (or similar) and engine.world.getName() that would return only "Level_01". I don't feel the path should be included in a getName() function for a world. I feel its a bug because if the same world was called in two different ways, the world "name" is different. I have fixed the problem in our project, this is more of an opinion/suggestion now. Thanks! Link to comment
manguste Posted June 16, 2011 Share Posted June 16, 2011 You can always use basename() function for that. It returns only the name. Link to comment
