burakdogancay Posted August 19, 2019 Posted August 19, 2019 (edited) I am trying to add collision process for nodes.I already created contactcallback for intersection and it works like charm when i implement it directly to editor with calling by function in c++.So it directly detect intersection and collision wit contact callback function. I would like to explain it with code; It works correctly with this way Unigine::NodePtr mObject1; Unigine::NodePtr mObject1parent; mObject1parent = Util::Search::getNodeRecursive("Objectparent", mReference->getNode()); mObject1 = Util::Search::getNodeRecursive("mObject1",mObject1parent); //I already added rigid body for object in unigine editor. mObject1->getObjectBodyRigid()->getBody()->addContactCallback(Unigine::MakeCallback(this,contact_callback));//contact callback function detects intersections for collision But I would like to remove Object1 from editor and add it dynamically with code. Unigine::NodePtr mObject1; Unigine::NodePtr mObject1parent; mObject1parent = Util::Search::getNodeRecursive("Objectparent", mReference->getNode()); mObject1 = Util::Search::getNodeRecursive("mObject1",mObject1parent); //I disabled object1 from editor(something like removeving from editor) //Then i added and created this object dynamically with below code: Unigine::NodeReferencePtr tObject1 = Unigine::NodeReference::create("External/Entities/Object1.node");//this nodereference has node with rigid body inside tObject1->release(); Unigine::Editor::get()->addNode(tObject1->getNode(),1); mObject1= tObject1->getNode(); mObject1->setWorldPosition(mObject1parent->getWorldPosition()); mObject1->setWorldRotation(mObject1parent->getWorldRotation()); //But unfortunately it does not get this Object1 node for collision, so below command gets trouble if we call rigid body of this node //Basically it acts like this node is not exists.But i can set its position and direction and even i can move it in any axis. mObject1->getObjectBodyRigid()->getBody()->addContactCallback(Unigine::MakeCallback(this,contact_callback)); Any help will be appreciated. Edited August 19, 2019 by burakdogancay
cash-metall Posted August 19, 2019 Posted August 19, 2019 1) a bit of optimization - don't decompose and compose the transformation matrix (if you don’t need it). This can lead to strange effects mObject1->setWorldPosition(mObject1parent->getWorldPosition()); mObject1->setWorldRotation(mObject1parent->getWorldRotation()); to mObject1->setWorldTransform(mObject1parent->getWorldTransform()); such code suggests that you have scale changes?? Physics does not work with scaling objects! 2) 48 minutes ago, burakdogancay said: But i can set its position and direction and even i can move it in any axis. how exactly? which node are you moving and how exactly? 3) 49 minutes ago, burakdogancay said: mObject1 = Util::Search::getNodeRecursive("mObject1",mObject1parent); //I disabled object1 from editor(something like removeving from editor) Disabled nodes are not deleted from the world. 4) According to the current code snippet, I can’t understand where exactly the error is. Сan you explain in more detail what exactly you want to do? Maybe some screenshots/videos?
burakdogancay Posted August 19, 2019 Author Posted August 19, 2019 So i removed this below code and node from editor now.(Unfortunately i can not share any video for this project cause of policy) mObject1parent = Util::Search::getNodeRecursive("Objectparent", mReference->getNode()); mObject1 = Util::Search::getNodeRecursive("mObject1",mObject1parent); //I already added rigid body for object in unigine editor. İ used below code directly. Unigine::NodePtr mObject1; Unigine::NodePtr mObject1parent; //Then i added and created this object dynamically with below code: Unigine::NodeReferencePtr tObject1 = Unigine::NodeReference::create("External/Entities/Object1.node");//this nodereference has node with rigid body inside tObject1->release(); Unigine::Editor::get()->addNode(tObject1->getNode(),1); mObject1= tObject1->getNode(); mObject1->setWorldPosition(mObject1parent->getWorldPosition()); mObject1->setWorldRotation(mObject1parent->getWorldRotation()); //But unfortunately it does not get this Object1 node for collision, so below command gets trouble if we call rigid body of this node //Basically it acts like this node is not exists.But i can set its position and direction and even i can move it in any axis. mObject1->getObjectBodyRigid()->getBody()->addContactCallback(Unigine::MakeCallback(this,contact_callback)); So my problem is , i can not reach the node but i can set its position and see the movement of the object according to its orientation.When i add contactcallback for this object it acts like it doesn't exist.Even i can not get its name by mObject1->getnode()->getname(), it return empty name for this object.
cash-metall Posted August 19, 2019 Posted August 19, 2019 try to change Unigine::NodeReferencePtr tObject1 = Unigine::NodeReference::create("External/Entities/Object1.node"); tObject1->release(); Unigine::Editor::get()->addNode(tObject1->getNode(),1); mObject1= tObject1->getReference(); // get Content node from noderef mObject1->setWorldPosition(mObject1parent->getWorldPosition()); can you show the nodereference structure from the editor?
burakdogancay Posted August 19, 2019 Author Posted August 19, 2019 Thank you so much problem is solved with " mObject1= tObject1->getReference(); " I wish you a good day.
