Clouds movement without noise
I just want to ask how it is possible to move the clouds without moving through the noise pattern to make their shape more stable.
I added two videos, one shows the movement of the player, which creates the appearance I want to achieve.
The other one shows the cloud moving per wind slider in the paramter section.
Ideally it should be a mix of both.
Thanks for your help.
Link to post
Hi Sebastian,
You can try to decrease visibility of noise by manual tweaking cloud material parameters such as:
  • detail distortion size
  • detail intensity
  • distortion force
However, fully remove noise from clouds, I'm afraid not completely possible - that's how volumetric clouds are rendered internally.
Link to post
1 minute ago, silent said:
Hi Sebastian,
  • detail intensity
  • distortion force
Is there a way to move the clouds like the effect you see in the video when I just move the viewpoint?
Link to post
So I should be able to move the clouds by changing the Position of a ObjectCloudLayer?
Link to post
  • 1 year later...
On 7/31/2020 at 9:16 AM, fox said:
Work-In-Progress
In the research branch we have even more improvements for the clouds (including support for Cumulonimbus) and the weather system in general, including a major upgrade of the regional weather system.
Please note that these improvements are under active development, they are planned to be available in full for UNIGINE customers in 2.13+ SDK releases.
just want to ask if you are planning to make the cloud layer moveable along other axis, to get more realistic cloud movement?
We are also interested in the upcoming Cumulonimbus cloud feature.
Is this going to work as a single cloud which can be moved along the world axis or is it the same texture aproach which gets repeated?
Thanks
Edited by sebastian.vesenmayer
Link to post
Can you use field weather somehow?
Link to post
Quote
There is a Wind Deformation setting in Parameters that adds some additional animations:
Quote
Right now it's still in the development stage. More likely it will be a separate type of object that can be moved separately and cloned as a regular node. It's quite different type of the cloud, so it would be hard to make it in the similar way that current clouds are implemented.
Link to post
Thanks, totally missed that while reading the documentation. :)
That would be exact the way we would like to use it. We are exited how this feature will look and work. :)
Thanks.
Link to post
depth_sorting.thumb.PNG.4abfef4d1adc9dd158697a12c79b872e.PNGdepth_sorting_2.thumb.PNG.272db435231b05122bbdb8a0548eb48d.PNG
I did some testing with two cloud layers and field weather, but depth sorting is a problem then.
Link to post
