arzezniczak Posted July 11, 2019 Share Posted July 11, 2019 (edited) I have imported FBX with animations using Editor. During runtime at some action I'm creating from it NodeReference in code: Unigine::NodeReferencePtr fbxReference = Unigine::NodeReference::create( "man_animated.fbx" ); I know that this object have 3 animations with 2 skinned meshes. In Editor to start playing animations I must select all skinned meshes of this object and hit Play under Mesh skinned section. But how can I achive same result from code at runtime? EDIT: Ok, so basically I created this code and it seems to work, but is this proper way of doing this task? Unigine::NodeReferencePtr fbxReference = Unigine::NodeReference::create( "man_animated.fbx" ); //...some transformation manipulations StartAnimationRecursive( fbxReference->getReference( ) ); ... void StartAnimationRecursive( Unigine::NodePtr node ) { Unigine::ObjectMeshSkinnedPtr meshSkinned = Unigine::ObjectMeshSkinned::cast( node ); if ( meshSkinned ) { meshSkinned->setAnimName( meshSkinned->getAnimationName( 1 ), 1 ); //TODO here goes the animation number to play, 0 seems to be "rest" pose (?) meshSkinned->setLoop( 1 ); meshSkinned->play( ); } for ( int i = 0; i < node->getNumChildren( ); ++i ) StartAnimationRecursive( node->getChild( i ) ); } Edited July 11, 2019 by arzezniczak Link to comment
morbid Posted July 12, 2019 Share Posted July 12, 2019 Hello, 17 hours ago, arzezniczak said: Ok, so basically I created this code and it seems to work, but is this proper way of doing this task? Yep that code is fine. 17 hours ago, arzezniczak said: 0 seems to be "rest" pose (?) Yes, by default fbx stores an empty animation and real animation sequence. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN Link to comment
