christian.wolf2 Posted July 1, 2019 Share Posted July 1, 2019 Hello, I am currently having an issue to find the surface of an object, a line is currently intersecting with. My code is a small tweak from the VR-demo and looks as followed: vec3 view_dir = VRPlayer::get()->getHead()->getWorldDirection(); vec3 pb = vec3(VRPlayerVR::get()->getHandNode(0)->getWorldPosition()) + VRPlayerVR::get()->getHandNode(0)->getWorldDirection(Math::AXIS_Y) * 0.05; vec3 pe = pb + VRPlayerVR::get()->getHandNode(0)->getWorldDirection(Math::AXIS_Y) * 50; vec3 dir = normalize(pe - pb); vec3 right = cross(view_dir, dir); Unigine::Vector<ObjectPtr> intersectionObjects; int foundObjects = World::get()->getIntersection(Vec3(pb), Vec3(pe), intersectionObjects); if (foundObjects) { bool foundSurface = false; for (int i = 0; i < intersectionObjects.size(); ++i) { for (int surface = 0; surface < intersectionObjects[i]->getNumSurfaces(); ++surface) { ObjectIntersectionPtr intersection = ObjectIntersection::create(); if (intersectionObjects[i]->getIntersection(pb, pe, intersection, surface)) { //we found the surface if (isObjectNodeToChangeMaterialFor(intersectionObjects[i])) { selectedObject = intersectionObjects[i]; foundSurface = true; break; } } } if (foundSurface) break; } if (foundSurface) selectionRay->setMaterial(rayMaterialGreen, 0); else selectionRay->setMaterial(rayMaterialWhite,0); } What I am trying to achieve is to check in my first step the number of objects, I am intersecting with. After that, I am iterating through each objects surface and check, which surface will be the right one. I am using no intersection mask. The current problem is, that I didn't get any valid surface, even if the intersectionObjects-list contains multiple ones, so I guess the World::getIntersection()-function are different from Object::getIntersection() regarding surface intersection. Or am I missing something? Link to comment
andrey-kozlov Posted July 2, 2019 Share Posted July 2, 2019 Hello Christian, Object::getIntersection expects points in local space and you provide them in world space. You could use Object::getIWorldTransform to transform them. Link to comment
christian.wolf2 Posted July 3, 2019 Author Share Posted July 3, 2019 Hello andrey, many thanks, using the getIWorldTransform indeed does the trick. Link to comment
