world spline graph
sorry couldn't find that in the doc:
can spline graphs be imported from any vector data.? Eventually with collapsed tangents if the source data is linear (ie, shapefile)
Or has it be done with a custom importer in order to fit the .spl syntax ?
Thanks
R
Link to post
At the moment World Spline Graph (WSG) is an experimental feature that will be polished to production stage at 2.9 (more likely 2.9).
It supports manually created splines only. However, you can use Landscape Tool to generate a spline object based on a shapefile (*.shp). Usually it works for roads or any other extended objects.
Here's some more info: https://developer.unigine.com/en/docs/2.8/editor2/landscape_tool/generate_spline
We have in plans native vector data import feature, but I can't give you any ETA.
Link to post
  • morbid changed the title to world spline graph
  • 1 year later...
