kongzhifei 0 Share Posted June 17, 2019 In my project ,I need some pose data ,whilch in need analysis this data by matlab ,so I decied output thoes data to .txt file ,but Idon`t know how to output this data ,Is there related API by UNIGINE script? or have other metholds ? Link to post
fox 125 Share Posted June 17, 2019 Hi kongzhifei, You can use the File class to output any data to a *.txt file, or in case you'll need to create an *.xml file, the Xml class. Both classes are available in C++, C# and UnigineScript API. The following C++ sample for the File class might also help: <UNIGINE_SDK_folder>/source/samples/Api/Systems/File (or choose Samples -> C++ API -> Systems -> File in the SDK Browser) Thanks! Link to post
