werner.poetzelberger Posted May 9, 2019 Posted May 9, 2019 Hey, I have the following idea: I have one skinned character with a specific mesh and skeleton as well animation sets. I have a second character, which has different proportions (body dimensions) for the skeleton, animations, which match onto that skeleton and a mesh. I want to morph/blend between the two characters with the least visible glitches over a certain time. So I need to blend between the 2 skeletons and the mesh (skin) and the animation sets. We have some ideas how it might work, and I guess we can 'fake' transitions like blending meshes over each other. (Thats the last thing we want to do) The ideal thing would be, that there is one character, which morphs into the other or vice versa. Scaling (or moving) bones to adjust the skeleton would be doable, the skinning would adjust according the new positions. So the skinning would have to be blended as well to match the new mesh and vertex positions (thats probably not so easy to do). There are definitely a lot things to consider, so I want to ask, if someone has done something like that before or if there are ideas about such a task. Thx Werner
silent Posted May 13, 2019 Posted May 13, 2019 Hi Werner, If you сan afford the same bones hierarchy between two models I guess you can try to use morph targets (blendshapes) for that task. However, that's all theory - we never did such trick before :) Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
werner.poetzelberger Posted May 13, 2019 Author Posted May 13, 2019 Right. We also have not really a reference. We are working on it. Ja, some mixture of existing techniques, morphing, blending will be our first tries. Will keep you updated here. Cheers. Werner
