ivan.cuevas Posted June 8, 2011 Share Posted June 8, 2011 In last Unigine version, when FontRich::parse() is called, the symbols are decoded before any parse operation. This is a problem because, for example this string: <p align="left">10<20</p> is converted to: "<p align="left">10<20</p>" and then starts parsing operations, this causes the following error: 10:05:27 FontRich::parse(): unknown tag "<</p>" In previous version, decode operation is done after text element is identified, I think this is correct way to do it. Why this code has been changed? Link to comment
eugene.litvinov Posted June 8, 2011 Share Posted June 8, 2011 Maybe this is because this was fixed: WidgetLabel rich text Link to comment
ivan.cuevas Posted June 8, 2011 Author Share Posted June 8, 2011 Maybe this is because this was fixed: WidgetLabel rich text Thanks for your answer Eugene. I think when you want to pass an xml string to any parser, the best way is to doit as follows: string s="<p align=\"left\">Is 10 < 20?</p>"; myWidget.setText(s); IMHO special symbols like '<','>','&', etc. used inside text elements can't be decoded before any parse process because this may cause invalid XML structures. I think the old way was the correct one. Link to comment
eugene.litvinov Posted June 8, 2011 Share Posted June 8, 2011 Afraid I don't understand you at 100 percent... but if you save your xml: <p align=\"left\">Is 10 < 20?</p> in a file and try to open in some xml editor or Internet Explorer, they show you an error: <p align=\" - this is not correct xml formatting. In Unigine xml must working as it working anywhere. Link to comment
ivan.cuevas Posted June 8, 2011 Author Share Posted June 8, 2011 Afraid I don't understand you at 100 percent... but if you save your xml: <p align=\"left\">Is 10 < 20?</p> in a file and try to open in some xml editor or Internet Explorer, they show you an error: <p align=\" - this is not correct xml formatting. In Unigine xml must working as it working anywhere. In my examples xml code is stored in a string variable ('"' must be scaped '\'): string s="<p align=\"left\">Is 10 < 20?</p>"; traduced to xml document: <p align="left">Is 10 < 20?</p> That it's well formed. Link to comment
